what to clean the throttle body with???
Old Mar 22, 2003 | 11:12 AM
bachehbad's Avatar
Ok my throttle body is a little dirty, what should i use to clean it? and how? i dont want any big particles to get sucked into one of my cylinders!!
Old Mar 22, 2003 | 11:31 AM
NOMAD's Avatar
Cool
Unbolt the throttle body and un hook the sensors, go buy some Carb Cleaner/ Throttle body cleaner and spray it down until clean
-Shannon
95TA8280's Avatar
Go to Autozone and get Throttle Body or Carb cleaner......both do the job. Tale off the black tube that goes from your TB and then just spray the stuff. Have a towel underneath it to catch all the stuff that falls down....Also, have someone there to step on the gas so you can clean the inside.
Old Mar 22, 2003 | 11:40 AM
mr diabolical's Avatar
seafoam's deep creep.
Old Mar 22, 2003 | 12:34 PM
RamAir95TA's Avatar
Don't use carb cleaner.
Fuel injected throttle bodies have an anti-carbon coating on them, and carb cleaner is caustic to that. Use recommended FUEL INJECTION or THROTTLE BODY cleaner.
Old Mar 22, 2003 | 01:54 PM
Bastardcat's Avatar
I had good results using Seafoam's Deep Creep.
Old Mar 23, 2003 | 09:26 AM
bachehbad's Avatar
ok i went and bought some throttle body cleaner and just sprayed tons down the throttle body while cleaning it with a toothbrush, looks pretty clean now, but i think i flooded my engine cause it took the car like 30seconds to start when i tried starting it.... then when it did start RPM's shot to 2000, after about 10minutes of driving everything went back to normal, now Idle is back to 800.
Peytons'z
May 6, 2021 09:25 AM
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
Fatdog2
Feb 13, 2015 08:19 PM
lt1-xjs
Jan 17, 2015 07:52 PM
