What to clean new cam with?
Old Aug 9, 2003 | 01:20 AM
Naegash's Avatar
Basically what the subject says, be as specific as possible (I'm sure that there isnt that much to it, I'm just one of those guys that has to make sure he has ALL the details right).
Old Aug 9, 2003 | 01:47 AM
AsianSensation's Avatar
Mineral spirit.
Old Aug 9, 2003 | 06:18 AM
Smokn '94 Z's Avatar
Arrow
Your new cam should be clean with a coat of oil on it. If dirt concerns you then just wipe with a rag & cover in more oil before application.
Old Aug 9, 2003 | 06:48 AM
Don 97 SS's Avatar
I don't know if this is the most correct method for removing the storage coating, but I sprayed mine with brake cleaner and then wiped it clean with a rag. I then used some Comp cam lube. I bought a jumbo container of it.
Old Aug 9, 2003 | 07:21 AM
97WRAITH's Avatar
I second the brake clean. Then lube it well with assembly lube. Be generous with the lube.good luck!
Old Aug 9, 2003 | 09:13 AM
Assembly Lube
Generous Amount of Assembly Lube
Klypto
Mar 23, 2016 09:05 AM
pimpss96
Feb 12, 2015 01:28 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
