what causes low coolant light?
The sensor gunks up; take it off and clean it well...if that doesn't work, replace it. It's easy to get to when you remove the battery. It's got a spring clip that slides off to remove the sensor. Be sure to drain your radiator first and don't forget to burp the radiator when you refill it.
Jan 23, 2015 01:13 PM
