Diagnostics say continous misfire....
Old May 25, 2004 | 07:22 PM
chief76's Avatar
Had a guy come over and look at the TA today. He put it on some sort of diagnostics, don't know what kind I wasn't here at the time. It supposedly said continuous misfire or something to that effect. He said it was probably one of 3 things, spark plug, burnt plug wire, or distributor. Anyone know about how much getting all the fixed would cost? I know the distributor is pretty hard to get to so I would have to have a shop do it but I'm just looking for a ballpark figure here. Also if anyone has any ideas on what else could possibly be causing this, that would be appreciated also.
Oh by the way, glad to join your group. 1st post!
Old May 26, 2004 | 12:16 AM
You might want to set up a "signature" showing the year of your car, the tranny type, and any major mods, as a minimum. That kind of info is required to anwer a question like the one you asked. If the scan showed a "misfire", we can assume its a 96 or 97, since those are the only LT1's with misfire detection. Do you know the exact diagnostic code?
Generally you will get a code for "random misfire" if its the distributor, while an individual plug or wire will show up as a repeated misfire on the same cylinder number.... something you can pull up with a scanner. By knowing whether its random, or one or two specific cylinders, you might have a better chance of finding the specific problem.
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
MichiganSkip
Jun 8, 2015 10:30 AM
May 1, 2015 01:14 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
