What are the causes of knock?
If I log my car, I get around 7 degrees of knock retard starting at the bottom of 2nd at WOT (~4000 RPM). At 5000 or so, the KR drops off and pretty much disappears by 6000. There is no KR in 1st gear. I know at least some of the knock is false, because before I put the LT4 KM in I was seeing like 10 degrees. Putting in the KM smoothed it out quite a bit. My trap speeds also went from 100 to 102 after the KM.
What could be causing my problem?
-low octane fuel
-carbon buildup in combustion chambers
-excessive inlet air temp
-excessive coolant temp
-lean A/F ratio
-too much spark advance
Have you run some 100-octane unleaded to see if it helps?
-lean A/F ratio
Thanks for the suggestions Fred.
Regarding carbon buildup in the combustion chambers, the motor does have 138k on it. Should I run some seafoam through it?
Inlet air temp is pretty cool. I can't remember exactly what it was but it was ok.
Coolant temp never gets above 187 degrees or so.
I'm not sure of the A/F ratio. The car only gets 16 MPG at best...
Spark advance. Bryan at pcmforless pulled quite a bit of timing out of it to see what that did, and it dropped the KR to around 5.5. So there was less KR, but it was still there.
I always run 93 octane, so that can't be it. I will try some 100 octane when my tank gets low in a couple days. If the KR goes away, then it's real knock right?
Fred this reminds me. I don't know if you remember arguing with me about flow #s with CAI's, but when I switched to the GM CAI my knock is at 0 at all times (might go to 1 in some cases). When the Ligenfelter was on it always went through 1-4 degrees in acceleration. Both stay at 0 at idle.
whitehooptie
Aug 10, 2015 07:02 AM
