What Causes an Irratic Idle (Surging/searching))
Old Jan 2, 2005 | 12:38 PM
NeedMorHP's Avatar
My car has the LT4 conversion with the PCM reworked by Ed Wright. Now after three years it will not idle right. It idles low so I turn the idle adjuster in and it idles too fast, turn it back to stock idle then it starts surging again. Is the TPS going out or is it something else?
Thanks,,
Old Jan 2, 2005 | 02:20 PM
dust6928's Avatar
Re: What Causes an Irratic Idle (Surging/searching))
might try taking the tb off and cleaning the idle air control valve real good and make sure it is functioning.
Old Jan 2, 2005 | 05:32 PM
OBE1 95Z28's Avatar
I second cleaning the IAC and passage way. Be careful cleaning it as it's delicate.
You might also check for vacuum leaks.
Old Jan 8, 2005 | 09:02 AM
NeedMorHP's Avatar
Thanks, This is where I will start instead of just start changing parts.
Thanks again,
68camaroboltz
Oct 5, 2015 01:46 PM
Double aught
Oct 2, 2015 11:29 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
