What is it capable of ?
Old Apr 1, 2004 | 05:19 PM
Blue ZR28's Avatar
Lightbulb What is it capable of ?
Hey everyone,
what are your opinions on the following setup, what times do you think it will be capable of running in the 1/4 ??.....also, I would appreciate it if you would take a guess on how much HP this setup will have.
It's a '94 Z28 with M6 and the following mods.....
- Borla cat-back exhaust
- Random Tech Hi-Flow cat
- AS&M headers/y-pipe
- GM 1LE Induction Elbow
- Moroso cold air
- MSD 6A
- Hypertech 160 T-Stat
- Hotchkis Strut Tower Brace
- BMR adjustable panhard rod
- BMR LCAs w/ bolt-on adjustable LCA brackets
- Eibach Pro-Kit springs
- Bilstein front/rear shocks
- SLP Flywheel, Steel Billet
- SLP Pressure Plate/Throwout Bearing
- SLP Clutch Disc
- Skip shift eliminator
- B&M Ripper
- Thunder Racing brake package w/ Power Slot rotors
Thanks a lot for your help,
Alex
Old Apr 1, 2004 | 05:52 PM
Blue ZR28's Avatar
anyone please ?
Old Apr 1, 2004 | 08:59 PM
unvc92camarors's Avatar
Re: What is it capable of ?
Originally posted by Blue ZR28
Hey everyone,
- Moroso cold air
- MSD 6A
- SLP Clutch Disc
- B&M Ripper
Alex
first off, check the thread at the top of lt1 tech, only 1 ttt in a day
and doing it after like 45 min. isnt helping too much either
just to warn you, people dont take too kind to that
but, anyways, onward to the question
the 1le elbow isnt going to do anything, dont buy it unless the stocker goes and gets cracked or something
second, the only thins giving you hp are the intake/exhaust so...i'm guessing around 280-290 or so rwhp maybe?
third, the lowering springs aren't helping you on the drag strip
i mean, granted you are getting lcas and relocation brackets which will help, i think it will be about stock for launching, maybe a little worse, but i cant blame you for wanting handling and/or the good looks of a lowered car
overall, prob net in the 13's somewhere i guess depending on how you can drive
looks like a strong setup though, pretty good autox/strip combo going there i think
o yea, and the msd 6A, you'll have to get some opinions on that
i'm not sure if it makes a big enough difference for the money or not
good luck though
Z Power
Sep 19, 2015 11:19 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
