What can cause a backfire out the intake??
Old Apr 21, 2005 | 10:17 AM
stockLT1's Avatar
My car is backfiring out the intake, what can cause that besides plugwires being out of order??
Just looking for other possible causes, Just to be sure I don't miss anything.
Thanks in advance..
Old Apr 21, 2005 | 10:47 AM
ajschult's Avatar
Re: What can cause a backfire out the intake??
Timing chain being off a tooth or more. Also improperly adjusted rockers.
Old Apr 21, 2005 | 10:56 AM
93transam1234's Avatar
That would happen to me when my fuel pump was going out, might want to get a gauge on her and test the fuel presure
Old Apr 21, 2005 | 11:08 AM
ajschult's Avatar
Just curious: have you done any work on your car lately?
Old Apr 21, 2005 | 03:02 PM
stockLT1's Avatar
fuel pressure is fine, timing chain is fine.
I went to 42# injectors.
96' harness
94' PCM
Got a new tune, but backfire is still there, just pops real loud out of the CAI.
No vaccuum leaks either.....
Old Apr 21, 2005 | 03:04 PM
stockLT1's Avatar
Checked rocker arms, changed plugs, and checked compression/ leakdown recently aslo.
Old Apr 21, 2005 | 03:52 PM
recheck that all the plug wires are going to the right opti port?
What kind of Inj. did u go with? why did u need such big ones?
Old Apr 21, 2005 | 08:20 PM
stockLT1's Avatar
Ohmed out plug wires and made sure they were going to the right cyl. All checked out good.
I needed the 42#'s for 396ci, 12:1, 300 shot N2O
Old Apr 22, 2005 | 09:55 AM
stockLT1's Avatar
Any other Idea's guys??
Old May 2, 2005 | 10:13 PM
ak_WRX_Z28's Avatar
is the intake backfire bad on the engine? i just put a trick flow elbow and now the backfire sound is louder. what's causing it? we just had it tuned up last year.
Old May 3, 2005 | 06:05 AM
Polo-94Z28's Avatar
Cool Re: What can cause a backfire out the intake??
I had a backfire out the intake ... long story short, scoped everything on the car with a dso... turned out to be the opti, installed a new one, problemo solved. Also, my misfire was only at a certain RPM... If that helps at all.
Old May 3, 2005 | 06:25 AM
BLinindoll's Avatar
mine does it too but only when letting off at about 6000 RPM's. Could it be caused by tired valave springs which would cause valve float? I have new plugs, new coil, new wires, new MSD ignition. Hope it's not the opti. I could settle for the tired valve springs because I'm doing a Hot Cam Kit right after I do headers, which hopefully isn't that far off in the future. BTW, 96K miles.
Old May 3, 2005 | 08:05 AM
Polo-94Z28's Avatar
You sure youre not hearing the exhaust... Ive got 133k on the clock and I dont get any intake backfires, not even after letting off at 6k. Then again, I don't let the throttle slam shut and leave it in gear. If you do that, then you get the exhaust popping sound.
Old May 3, 2005 | 09:02 AM
30696bird's Avatar
I also had the same problem/ same results.
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
Chet1185
May 10, 2015 09:24 AM
Noenav
Apr 30, 2015 01:06 PM
Drtryder
Apr 22, 2015 04:17 PM
F(ast)-body
Feb 26, 2003 09:05 AM
