what cam lube should i get
Re: what cam lube should i get
You don't need assembly lube like a non-roller cam would use. I used the
GM EOS (engine oil supplement) for this purpose and it worked fine. You
can search on this topic for lots of info.
I would go so far as to call a heavy "cam lube" a BAD idea. Those are meant for getting flat tappets to spin and mate to lobes that is not an issue we need to worry about. Engine oil or the like.
carguyshu
Jan 22, 2017 11:19 AM
Hurin
Dec 13, 2014 07:38 PM
