What is this cam.....
Old Jul 29, 2005 | 04:46 PM
fasteddie94's Avatar
Here are the specs 236/242 dur, 585/576 lift, 112 lsa. I just pulled the cam specs on the longblock i am looking at and I want to know how to determine how this or any cam would act in an LT1. I have never been able to understand the numbers and relate them.
BTW--It's a 396 LT4 stroker
Old Jul 29, 2005 | 05:03 PM
raroz28's Avatar
Re: What is this cam.....
seems like a combo motorsports grind.
http://www.cmotorsports.com/engine/l...ft-design.html
TN-236XL 236/242 duration, .555"/.576", 112lsa
Has a different intake lift though. That cam would be a monster. Excellent choice I think. I would love to hear that thing
Old Jul 29, 2005 | 05:08 PM
jerminator96's Avatar
Its a high end cam, you'll make alot of power from mid to high rpm. Good choice by the way
Old Jul 29, 2005 | 05:11 PM
How can you determine it's a monster? I just don't understand how to transfer the numbers to how it would act in the engine. And it's a comp cams setup used in the golen engines 396 LT4/520 package.
Old Jul 29, 2005 | 06:00 PM
The first numbers are the duration for the intake and exhaust (degrees of rotation that the valve is open) the next 2 numbers are the lift of intake and exhaust valves (the height they open in inches) Long duration+big lift=lots of air flow. And as i'm sure you know, good airflow usually equals lots of HP. But your cam does of course need to be matched with the flow capabilities of your heads to achieve the best hp gains. A .600 lift is at the beginning of what most girly-men call "not streetable" IMO.
Old Jul 29, 2005 | 07:32 PM
I say F STREETABLE!!! I need more power!! The heads in question are matched to it. The whole package is supposed to put out 520 at the crank plus I am going to get my intake ported.
Old Jul 29, 2005 | 07:36 PM
Last question: how do you determine where the powerband is?
BLUETOPTA
Apr 3, 2008 02:17 PM
reamo04
Jan 23, 2007 05:05 PM
1984camaroz28
Oct 17, 2006 03:54 PM
toofast10
Sep 2, 2006 04:12 PM
96LT14u2Nv
Nov 15, 2004 07:54 AM
