what cam for a 383 stroker?
#16
Re: Re: what cam for a 383 stroker?
Originally posted by S.J.S.
Just outta curiousity..what dont you like about the hot cam??? If you look at my specs below...
#17
Re: Re: Re: what cam for a 383 stroker?
Originally posted by chesee48
what are your numbers with the 383 and the hotcam?
#18
Originally posted by 383WS6
the intake is ported to 58mm and polished but for some reason they only went w/ a 52mm TB w/ an airfoil.
#19
www.cmotorsports.com
thats all i have to say
#20
I personally like the looks of the 227/233 duration, .560"/.569", 111lsa.
That would definitely perform well in a stroker, especially with those lift numbers on some good heads.
#23
I was looking at the camshafts list on
http://www.cmotorsports.com/
Is anyone using this cam on his 383LT1 engine.
TN-230XH: 230/236 duration, .622"/.624", 112lsa
The lift is at 1.6rr
How is the performance of the cam work with LT1 ported heads.
How is the duration for a street/strip car with A4 and stock converter.
#24
the duration is fine for drivability,and daily driving....I don't know about the performance of that high of lift, with stock heads??? If you did go with stock heads, I would get the full p/p, bigger valves,etc...
If your going to decide on that kind of cam, I wouldn't waste it on a car with a stock converter....if you still have a stock converter, I wouldn't get too radical of cam then....Otherwise, get an aftermarket TQ....32-3500rpm converter would be fine...
10-31-2016 11:09 AM
