What cable
Old Jan 22, 2006 | 05:37 PM
rock1501's Avatar
What cable
I have a 1996 Camaro with the obd2 connector and I have a obd1 conversion pcm.I am going to buy tunercat for obd1 and I need to know what cable to buy.
Old Jan 23, 2006 | 11:49 AM
rock1501's Avatar
Re: What cable
Anyone
I tried emailing a few places that sell cables but it seems customer service is not good these days and they didnt respond back
Old Jan 23, 2006 | 11:57 AM
roughneck427's Avatar
Re: What cable
Hey go here i bought it for 40 bucks and it does obd1 and 2 style connectors www.mastach.com even comes with some cool free software ive already used it to tune my 95 worked great
Old Jan 23, 2006 | 12:32 PM
Jameslt1TA's Avatar
Re: What cable
Get a cable for a 95. In 95 they used the obd1 computer but the cable is a obd2 style plug. Im not sure where i got mine it was amk or akm or something like.
Old Jan 23, 2006 | 12:46 PM
RE AND CHERYL's Avatar
Re: What cable
Thats not gonna work. The pin arangement was totally different. I'm going through this myself as I installed a post 97 dash and interior harness. So now I have an OBD I PCM but a OBD II connector. The only two wires you should need to scan the car are a power and PCM wire. Both of wich lead back to the PCM. You should be able to an OBD II cable. I'll have to throw the scanner on my 94 and see what happens.
Old Jan 23, 2006 | 12:55 PM
Re: What cable
Well I just tried to scan my car using my Auto-Xray scanner. I used my OBD II cable but scanned it as an OBD I. NOTHING... Also tried to scan it as an OBD II with the same result.
I'd get up with AKM cables and ask them what you need.
Old Jan 23, 2006 | 04:53 PM
Z95m6's Avatar
Re: What cable
A 95 cable will work. My buddy has a 97 with an OBD1 pcm and he uses a 95 style cable.
Old Jan 23, 2006 | 11:14 PM
rock1501's Avatar
Re: What cable
I hope so I dont want to spend the money and it be worthless
Old Jan 23, 2006 | 11:48 PM
Z95m6's Avatar
Re: What cable
It should work if it doesn't you have some other problems. I've used my cable for my 95 on my buddies 97SS and i've used it on my other buddies 97Z. My friend with the 97Z has used his on my car as well and on the other guys 97SS. So if it doesn't work for you, you have other issues.
Old Jan 24, 2006 | 04:44 AM
Re: What cable
I'll try my 95 cable with the Auto Xray today and let ya know.
Re'
Old Jan 24, 2006 | 07:43 PM
Re: What cable
The 95 speciffic cable would not work with my Auto Xray. Don't know if the problem is related to the OBD II connector with an OBD I PCM or not. I suppose it will just be easier to install an OBD I connector and be done with it.
Re'
Old Jan 24, 2006 | 08:25 PM
Z95m6's Avatar
Re: What cable
Re'
Thats OBDII connector with an OBD1 pcm isn't the problem, thats how 95's are. An OBDII connector with an OBD1 pcm.
Old Jan 24, 2006 | 08:45 PM
blazzinbird's Avatar
Re: What cable
ok here is what you do
go to http://akmcables.com/ic.htm and you want item number 2. if you are using a newer laptop you prob wont have rs232 cable port, so you need to get the usb kit cost is 90 dollars.
dont let anyone tell you it wont work cause they are fullof crap.
I have a 96 with a obd1 conversion, and it is what i use.
chuckd4more's Avatar
Re: What cable
Exactly. I have a 95 and scan it with AUTO XRAY OBDII connector. With the AUTO XRAY, it has to to set up(loaded) for whichever PCM you are scanning(OBDI or II). The connector doesn't determine the PCM.
Old Jan 25, 2006 | 03:11 AM
rock1501's Avatar
Re: What cable
thankyou
