what to buy
Old Jul 27, 2003 | 06:32 PM
WhoomWhaatWhaah's Avatar
what to buy
engine is out car and a new to me used motor will bo going in later next week. what should i buy while the motor is out.
My list so far is:
Hyperflex bushing kit $165 from summit
GoodYear Hi miler kit $100 from jcwhittney
Solid Motor Mounts ???
I already bought moroso blue max wires, accel coil and ngk plugs.
Old Jul 27, 2003 | 07:14 PM
QCKZ28's Avatar
is the car modded any?
Old Jul 27, 2003 | 08:55 PM
i relocated the intake air sensor, otherwise it's pretty much stock
Old Jul 27, 2003 | 10:38 PM
QCKZ28's Avatar
im giving my opinion based on the car will be on the road in cali.
i suggest poly motor mounts.
headers
ported and polish heads with good springs and bigger valves
new o2 sensors
cold air induction
have the intake ported for a 58mm (might as well while its apart)
and port match in to your heads.
52/58mm TB if you do heads/cam or stroker
a "better" cam
might as well put a higher stall TC while its accessible
electric water pump
double roller timing set
you could have a stroker built
i suppose you wanted to mod it??? its so much easier when the motor is out.
Jesse
Old Jul 27, 2003 | 10:58 PM
Z95m6's Avatar
at least do headers while it is out, but i would recommend a cam and probably heads too.
Old Jul 28, 2003 | 11:41 AM
Can't afford new heads such as the 195 afr lt4, group purchases on this board suck, you guys back out more than Grey Davis. I picked up a 95 z28 for 1500, the trans is trash, but the motor was good, as well as the rest of the car. I will upgrade to power everything in the car, fog lights, airbags, dash pieces, hood, fenders, and anything else i need for my heap.
Old Jul 28, 2003 | 11:44 AM
KCFormula's Avatar
At least do headers and roller rockers with valvesprings.
BTW what are you doing with the '93 motor?
Old Jul 28, 2003 | 11:50 PM
my mechanic is doing the work on my car for the motor, you don't want anyway, it has cracked heads and I drove her hard till she died.
warmeck
Jul 17, 2015 01:36 PM
cmsmith
Jun 4, 2015 07:35 PM
NewsBot
Jan 8, 2015 11:29 PM
