What Brand Tranny Fluid Do You Recommend?
Old Jul 10, 2003 | 03:30 PM
  #16
InjectedSS's Avatar
Originally posted by MrBigXL
LOL
but i'm using Redline synthetic D4 in a M6 and it's never shifted better!!!
maybe so! but as with anything like was said above once you get into the high HP range and start pulling consistent low tens at the track you will switch to regular!
the thing is, synthetic is a friction modifier and the m6 tranny syncros work on friction so you do the math
its not AS bad in the auto to run synthetic but it CAN cause SOME slippage if you start getting into the high HP ranges! but by then you should be on your way to a race prepped tranny anyways if your running an auto
Old Jul 10, 2003 | 03:34 PM
  #17
95 WHITE TRANS's Avatar
Dexron III and tranny cooler, running good so far (KNOCK ON WOOD).
NICK
Old Jul 10, 2003 | 06:55 PM
  #18
ssz28's Avatar
What about TCI's fluid? I heard that B&M fluid sucks.
Old Jul 10, 2003 | 07:40 PM
  #19
Jason E's Avatar
OK, so I run past 4,500 RPMs in a near stock car once in a blue moon...is synthetic ok for me, or should I drain it now? Never once had I heard of synthetic being bad for a 6 speed until this thread...I'm rather interested by what people are saying about the 6 speed.
Someone brought up the GMHTP magazine issue with their car...I have always looked at synthetic as cheap insurance, just like they said! Am I wrong?
Old Jul 10, 2003 | 08:38 PM
  #20
mike 96 ws6's Avatar
tranny fluid
i'm planning on a transgo shift kit for my 96 ws6 pretty soon. i heard of a fluid called "Mystic type-F". what's this? i've run type F fluids in gm hydromatics before the "e" computer controlled trannys, and got good results from a "shift firmness" point of veiw. is this fluid compatible with the 4L60E tranny in my car?
http://www.cardomain.com/id/lectrocrew
thanks!
Old Jul 10, 2003 | 09:26 PM
  #21
Old Jul 10, 2003 | 09:32 PM
  #22
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
A GM drivetrain engineer who gets paid to do R&D on the 4L60E (ie blow them up and try again) told me to use Fords fluid. It helps a bit.
Old Jul 10, 2003 | 10:05 PM
  #23
i sure don't want to, " blow up" anything on my car! that's why i asked. my lt1 is stock, so i'm not pushing 400 horses or anything near it. i'm just wondering if the type "f" fluid is better to run {for shift firmness} and if it is going to be bad for the seals, ect. i've been told it will increase the firmness, but , i don't have the $ to "blow it up". i have stock pcm program. should i stay with dextron III fluid when i install the transgo shift kit?
Old Jul 10, 2003 | 11:28 PM
  #24
InjectedSS's Avatar
this is what i have heard from a LOT of respectable people! 11sec to 9sec cars! it makes sense! I totally agree about putting the best in and i used to use synthetic until i heard about what im telling you! i dont mind paying more to save a lot! running synthetic wont hurt anything i dont believe but it does make the tranny work against itself!
chevy95z28
Jun 22, 2015 09:28 PM
BigWil
Mar 29, 2015 12:24 PM
alliance12364
Mar 6, 2015 04:39 PM
97TA-WS6-Con
Jan 10, 2015 05:31 PM
Catmaigne
Dec 25, 2014 12:16 PM
