What is the best way to manually turn the crank?
Old May 25, 2005 | 02:47 PM
  #16
30696bird's Avatar
Re: What is the best way to manually turn the crank?
Originally Posted by 96LT1TX
I've always adjusted my roller rockers w/ the car running at idle.... why am I the only one to suggest this?
I don't like to do it that way because I like my engine bay clean............and that way causes oil to shoot out. Maybe I do it while the oil is to cold and pressure is to high.
Old May 25, 2005 | 04:10 PM
  #17
NBred94's Avatar
I am installing new valve springs as well, so I was planning to rotate the crank incrementally to bring the pistons up to TDC to avoid dropping a valve into the cylinder. I was not set on how I was going to adjust the valves yet.
Another thing that I thought of, I will have to reattach the AIR tubes to the headers if I adjust the valves while running, and thes take them off again to install the valve covers. Not a big deal, but I'd rather not have to do that.
Chevyguy358
Jan 28, 2015 08:04 PM
Alex Barnes
Jan 24, 2015 10:21 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
formula79
26
Aug 5, 2002 12:21 PM
