WHat is the Best(Easiest)way to adjust valves?
Old Oct 2, 2005 | 09:32 AM
stepuptata's Avatar
I have a 97 Z28. Comp-R lifters and 1.6 roller rockers. What is the best and easiest way to re-adjust these. I pulled the valve covers and with the valve closed all the way, there is a little play between the rocker and the pushrod . Is this normal? Thanks.
Old Oct 2, 2005 | 09:54 AM
Jameslt1TA's Avatar
Re: WHat is the Best(Easiest)way to adjust valves?
Is it already running? If it is i would just start it up with one valve cover off. Loosen the rocker untill it starts clattering then tighten it to when it just stops. Then set you preload which is 1/8 of a turn i think for comp rs.
Old Oct 2, 2005 | 10:08 AM
It's all a matter of preference. No one will agree that there is one easy way. There are multiple ways presented here.
Old Oct 2, 2005 | 10:32 AM
truedualws6's Avatar
I prefer the Shoebox Method 1 or Method 2. Even though I have been using
Method 1 about 20 years before visiting this site for the first time, the info
on the Shoebox site is so nicely done and helpful, it's worthy of official
recognition as the Shoebox method.
I am assuming you have 7/16 rocker studs. If so, I have the same setup and
set the lash to 1/32 turn last time and the car runs great.
Old Oct 2, 2005 | 11:24 AM
Fastbird93's Avatar
As picky as I've found my Comp R's to be, I've found that the method that works best for me is method 3 on shoebox's page.
But like shoebox said, ask different people, get different answers.
Old Oct 2, 2005 | 11:31 AM
Z-RATED94's Avatar
I'm with Fastbird93. Car never ran right with the Comp Rs until method 3 was used.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
BPS
9
Mar 5, 2015 10:51 PM
