What Aftermarket radiator are you using?
I am Having problems keeping my engine running cool with my new setup. I have the stock fans and radiator, 160 thermostat and electric waterpump. Everything is fresh...coolant, pump, flush...but i still cant keep it below 210* in 85 degree weather. I was wondering what type of radiator you have had experience with and if you like it. the only ones i really have paid attention too are the BeeCool radiators in Summit mag...any experiences with these? Thanks
Chad
Chad
I got an AFCO in mine, but it's not quite the traditional style radiator (sits straight up, rather than at a rake). You might want to talk to Portell's down by you. They were gonna build my radiator until I got a deal on the AFCO stuff through the shop.
Are you using any block fill?
Do you have the air dam in place?
I have the Griffen... think it was about $500. I routinely run at 195degF in all weather. Stock water pump, Dex-Cool, Water Wetter. The only time I ever had a problem with cooling was when the shop forgot to put the air dam back under the car. It would run 210-degF at high speeds on the freeway. Put the air dam back on and it ran fine.
Location: I reached back like a pimp and smacked that LS1....
A stock radiator should work just fine, but we sell the Griffin radiators at $439.00. Takes about 3 weeks to get them.
www.ls1speed.com
www.ls1speed.com
Thanks for the replies. I dont have any block fill, and my air dam is in place. I never could figure out what was up with my cooling system...it just always ran warmer than it should, around 185, even with a very mild setup. now its becoming a problem with my engine runnin 220ish after running a while. It has to be the radiator, i think i have replaced everything else. Injuneer, you have an e-mail on some info on the radiator you are using. Intmd8, i will be calling you friday on some info on the griffen radiator.
Chad
Chad
Chad
Chad
Did you try flushing your system? Also are you fans programmed to come on early? A stock radiator should be more than adequate to support your setup.
everything was flushed, i just re-built the engine, and everything was empty and washed out. It has to be the radiator, i dont believe there is anything else i havent tried. Right now i have my fans on constantly and it lingers around 185 for about 10 mins then rises up to 210 after about 20 mins total. I dont know whats up, but this is a pretty hot engine setup i have here and the stock rad. looks pretty dinky...so i dont know.
Chad
Chad
