What 7/16 Studs are the way to go?
Old May 31, 2003 | 01:07 PM
Rico's Avatar
Are there differences in the 7/16 studs you can use or are they the same for us Lt-1 guys, I see ARP's, comps, and many others which to buy? I'm going with guide plate's and non sa.
Thanks for any help.
Old May 31, 2003 | 01:10 PM
jkipp84's Avatar
I used Comp 7/16" studs with their guide plates when I did my XE swap.. but I'm sure the ARP's are good too.
Old May 31, 2003 | 01:21 PM
Rico's Avatar
Did you ever find the lower portion of the rockers real close to the head of the stud, mine are real close, I just thought there would be a little more room under there.
Old May 31, 2003 | 01:23 PM
jkipp84's Avatar
You know, I never noticed! Not having any problems though.. Should be ok (I assume).
Old May 31, 2003 | 01:29 PM
Rico's Avatar
Yah! I guess.
Old May 31, 2003 | 04:44 PM
Bud M's Avatar
CC 7/16 studs work fine on LT1s.
Old May 31, 2003 | 05:20 PM
Phatcaprice's Avatar
What part numbers for LT1 studs? ARP, COMP? Because looking at the studs I pulled out of my aluminum heads, they have a 1/2" thread length, not the more common 3/4" (+/-) length. The ones I've seen look to damn long to put in there.
Old May 31, 2003 | 06:49 PM
Smokn '94 Z's Avatar
Re: What 7/16 Studs are the way to go?
I have the guide plates & studs for sale if interested. LMK
Here is the thread in the F/S section.
For Sale
13qtr
Oct 28, 2016 08:11 PM
karpetcm
Sep 15, 2015 11:07 AM
mmf_1013
Sep 12, 2015 08:56 PM
Daluchman1974
Sep 11, 2015 06:12 AM
FryedClutch
Sep 1, 2015 08:24 AM
