what it??
Old Mar 31, 2008 | 08:56 PM
northdakota93z28's Avatar
what it??
what if i put in forged pistons and aluminum heads and bumped the copression to 11.5 or so and ran a pretty big cam? would this make some good hp? it would be cheap.
i am really just talking out my a$$ so set me strait.
my goal is low 11s
Old Mar 31, 2008 | 09:13 PM
GreasyB's Avatar
What engine are you working with? And probly need more details.
Old Mar 31, 2008 | 09:17 PM
my 93 lt1
Old Mar 31, 2008 | 09:22 PM
GreasyB's Avatar
It already has aluminum heads...... I have no idea what you are trying to do. You just want to know what it takes to run 11's?
Old Mar 31, 2008 | 09:38 PM
Stl94LT1's Avatar
Ahhhhhh, yes you are!!! j/k
MEAN LT1's Avatar
Going by the mods you have have already. A good heads/cam package will get you there.
Old Mar 31, 2008 | 10:13 PM
96capricemgr's Avatar
Porting is the key to performance and good porting is not cheap but gets good results for the money. 11.5 is not that high a compression ratio for an LT1, with good quench and the right cam over 12:1 is done fairly often.
My car made 290rwhp with a ZZ4 cam and untouched iron heads, the swap to ported aluminum heads a thin gasket and a cam only in the mid 220s duration pushed that number up substantially. Do not have dyno numbers but the performance says at least 390rwhp meaning a gain of 100rwhp or more over an already cammed setup. Compression is 11.2-3, heads milled to 53cc and used a .026 gasket with pistons .026 down, virgin shortblock, never even pulled a bearing cap.
Old Apr 1, 2008 | 11:02 AM
i want to run pump gas, we dont have 93 octane so i dont want to go to hight on the compression. what about edelbrock heads from summit, and a good cam, but i think if i do that i will not be able to spray any more? right?
Old Apr 1, 2008 | 11:11 AM
What is your elevation above sea level. If you in the "mountains", you don't need 93 octane fuel, that's typically why you don't have it.
Static compression ratio is not what determines octane requirement. Its the dynamic compression ratio, which reflect, among other things, the overlap in the cam.
The Edelbrock LT1 heads are no different than the stock heads. The Edelbrock LT4's are better, but you can get the same level of performance from ported stock heads/matching cam. Try one of out Supporting Vendors.
Old Apr 1, 2008 | 11:20 AM
3000 feet
Old Apr 1, 2008 | 11:33 AM
If you are at 3,000-ft (~26.1 "Hg), you are losing 10% of the compression compared to sea level (~29.9"Hg), due to the fact that the air in the cylinders is less dense. Running 11.5:1 should not be a problem.
Old Apr 1, 2008 | 01:11 PM
cool thanks!
i have been reading all morning and i think i will go with a le2 h/c with stock bottom end.
