What #30 lb. injectors do you use?
Old Sep 17, 2003 | 03:00 PM
john97z28's Avatar
I have a bunch of new parts to install and need to upgrade my fuel system, particularly the fuel injectors. I want to go with #30lb. injectors. I've heard only good things about SVO's. Bad things about ACCEL. Does anyone use Bosch injectors? I found them a little cheaper than the SVO's, just wondering how their quality is.
Old Sep 17, 2003 | 03:10 PM
Gripenfelter's Avatar
Bosch is basically SVO now.
I have SVO. I don't think there are any major differences bwteen SVO and Bosch.
Old Sep 17, 2003 | 03:17 PM
Fastbird93's Avatar
Another one here using SVO 30# in one car ans 24# in the other car.
Old Sep 17, 2003 | 03:22 PM
john97z28's Avatar
Thanks for the quick responses, anyone else?
Old Sep 17, 2003 | 03:25 PM
AndyB's Avatar
Currently stock injectors. With the 383 i am going tobe using 30lb SVO's
Old Sep 17, 2003 | 03:44 PM
S.J.S.'s Avatar
Bosch 30's. From what I hear Bosch makes the SVO's
Old Sep 17, 2003 | 08:09 PM
hvyss's Avatar
The SVO's are Bousch. I use the SVO 30lb injectors with the 230/236 XE cam. A friend bought the Accel 30lb and could not get them tunned. Most of the major tunners do not like the Accels for that reason, including Bryan Herter and Ed Wright. If I am not mistaken Ed Wright wont tune a car with them. The SVO's are cheaper too. 219.99 thru Summit vs 259.00 for the Accels. Good luck.
HVY SS
Old Sep 17, 2003 | 08:20 PM
SloTexanTA's Avatar
I had Bosch 30# in my Z28, worked real nice. I also haven't heard anything good about the Accels.
Old Sep 18, 2003 | 02:03 AM
Zepp's Avatar
383 Stroker with Accel 32# injectors. They have worked great. I also didn't have any problems getting my car Dyno tuned with them.
Old Sep 18, 2003 | 07:29 AM
Derrick Redd's Avatar
SVO 30#
Old Sep 18, 2003 | 07:50 AM
john97z28's Avatar
I'm going with the SVO's, thanks to all who replied!
Old Sep 18, 2003 | 05:48 PM
97 RedSS's Avatar
What is so different about accel injectors that makes them hard to tune?
Cody
Old Sep 18, 2003 | 05:59 PM
Z95m6's Avatar
I have SVO 30lb. I have hear Accels suck because they aren't calibrated correctly. You might buy a set of 30lb ones and some might only flow 28lbs some might flow 31lbs and it screws everything up. That is just what i had heard.
Old Oct 20, 2003 | 10:05 PM
12SCNDZ's Avatar
Accels in mine, and running 12.25....
Frank
Old Oct 20, 2003 | 10:16 PM
flyinZ's Avatar
Same here...I have Accel 30#s in my 383, and there fine...
