What #30 lb. injectors do you use?
I have a bunch of new parts to install and need to upgrade my fuel system, particularly the fuel injectors. I want to go with #30lb. injectors. I've heard only good things about SVO's. Bad things about ACCEL. Does anyone use Bosch injectors? I found them a little cheaper than the SVO's, just wondering how their quality is.
The SVO's are Bousch. I use the SVO 30lb injectors with the 230/236 XE cam. A friend bought the Accel 30lb and could not get them tunned. Most of the major tunners do not like the Accels for that reason, including Bryan Herter and Ed Wright. If I am not mistaken Ed Wright wont tune a car with them. The SVO's are cheaper too. 219.99 thru Summit vs 259.00 for the Accels. Good luck.
HVY SS
HVY SS
I have SVO 30lb. I have hear Accels suck because they aren't calibrated correctly. You might buy a set of 30lb ones and some might only flow 28lbs some might flow 31lbs and it screws everything up. That is just what i had heard.
Originally posted by Zepp
383 Stroker with Accel 32# injectors. They have worked great. I also didn't have any problems getting my car Dyno tuned with them.
