What 1.6 RR's add the most HP?
Like facelessZ said, they are all about the exact same. They all do the same thing. I also fell that crane, and comp makes the best. But a lot of people are using the Scorpian 1.7rr's with low lift cams or stock cams and seeing good gains.
I plan on doing a Cam swap later on....but it is ideal to have these on and bust some heads in the meantime (if you know what I'm sayin
If I did an upgrade to the Rockers now would I have any problems later on when I switch to the new cam?..Meaning when you do a Cam swap do you have to install New rockers as well.
What place has the best prices on the RR's?
If you're planning on installing 1.6 rr's right now and a cam later...there's no point in changing the rockers again after the cam install....it's not necessary...but if you decide to install a cam definitely step up from the stock rockers...
