What The **** ASR off and ABS INOP!!
Old Oct 19, 2003 | 07:50 AM
gsdz28's Avatar
I was driving home yesterday, and out of no where my ASR off and ABS INOP lights came on and won't go away. when i turn the car off the turn off but a few miles down the road the come right back on.
what in the hell is going on?!?!?!?!?!?
Old Oct 19, 2003 | 12:06 PM
gsdz28's Avatar
TTT need some help, please. Before I push this thing off a cliff.
Old Oct 19, 2003 | 12:15 PM
96z's Avatar
96z
Do you have any codes? Go check underneath the car and see if the harness is still connected to the back of the brake backing plate. You may also need a new sensor, which screws into the brake backing plate.
Old Oct 19, 2003 | 02:15 PM
gsdz28's Avatar
can I get a little bit of a better idea on where the harness is???
Old Oct 19, 2003 | 05:15 PM
OBE1 95Z28's Avatar
A bad ground connection can cause a "light show" on the dashboard. Clean the ground post that located on the passenger side fender next to the red positive cap. Remove the ground stud and scrap away the painted surface underneath. This is a common problem; GM relies solely on the threads of the stud to make the ground connection.
Old Oct 19, 2003 | 05:26 PM
N2OpwrdTA's Avatar
Im having a hard time remembering...but I think that when I used to turn off my traction control via pulling my Relay in the box on the driver side, engine bay fuse/relay box......that it would cause my ASR, TCS and ABS inop lights to come on. Maybe your relay up there is bad!?!
I had to do that to turn off my traction control becaue my car did/does not have a button to turn it offl. Now that I have LT1 edit....I turned it off via PCM and now my ABS and stuff works.
Old Oct 20, 2003 | 02:25 PM
gsdz28's Avatar
i'll try both thanks guys.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
TGGodfrey
Aug 17, 2015 08:43 PM
tnmotown
Aug 10, 2015 11:52 PM
