Wet or Dry?
Old Jul 30, 2003 | 01:11 PM
94 CAMRO Z28's Avatar
Wet or Dry?
Wet or dry kit? Whats safter and whats better? Why? Cost? thanks
Aaron
Old Jul 31, 2003 | 02:33 AM
Anyone?
Aaron
Old Jul 31, 2003 | 03:11 AM
PredatorZ28's Avatar
i allways like;um wet
Old Jul 31, 2003 | 03:23 AM
Kain's Avatar
Re: Wet or Dry?
Aaron
Wet, thats what I had, and I'll be going to direct port sometime when I get the money for the new setup.
Wet is when you tap in fuel from the fuel rail and shoot nitrous and fuel in after the MAF.
Dry is when you shoot nitrous at the MAF, it picks up colder air, and extra oxygen coming in and uses the fuel injectors to add in extra fuel.
Wet pro's:
1)Harder initial hit, or better feel.
2)Takes the strain off of the fuel injectors to add in fuel, so you won't have to buy bigger ones, and if a fuel injector locks up on the bottle, you won't loose a cylinder.
Wet con's:
1)Remote chance of fuel pooling up in the intake manifold, a purge kit helps solve this. Most people thing a nitrous backfire is when fuel pools up in the intake manifold and explodes, almost no nitrous backfire cases are caused by pooling fuel.
2)Harder to hide.
Dry pro's:
1)Easy to hide, since you don't have to plumb the fuel rail for the wet side. If you try to hide a wet kit, if your getting fuel from the fuel rail, anyone who knows there stuff can look at it and know your running the bottle.
2)Costs a little less.
Dry con's:
1)Won't hit as hard as a wet kit, won't feel as cool.
2)If something goes wrong with a fuel injector, or they arn't big enough for the shot your running. Badness will insue.
Probably if you asked or searched for this in the Nitrous forum, you'd get more answers.
Old Jul 31, 2003 | 02:27 PM
Thanks Kain thats what I was looking to find out.
Aaron
Jeff1904
Jun 5, 2016 05:00 PM
RUENUF
Mar 13, 2016 03:37 PM
NewsBot
Jul 29, 2015 08:10 PM
Boss002
Jul 24, 2015 10:47 AM
Boss002
Jul 9, 2015 03:33 PM
