went to track not happy..
Old May 24, 2006 | 10:40 PM
93yellowta's Avatar
went to track not happy..need help arching
Went to track not hapy only pulled a 13.5 at 103.. that is only 1/10th. and 3 mph. better than before heads and cam.. still have cam surge, need alittle more tuning.. but I thought it should do better than that.. got home and opened the hood..looked like a christmas tree.. I have a new accel 300+ system. the coil had a steady blue streak running down each side of it, actually horizontal, the back driver plug had a steady ark by the boot, and the other three were lighting up intermittedly, one on the inner body of the car. the pass. side all were lighting up every 5-10 sec. not as much.. any ideas, the plugs are new gapped at .045 the wires are moroso's spiral wire 8.5 only 6 months old the 300+ system is only 1 week old, could it be the motor not grounded good enough, and also the accel plug that plugs into the coil only cover one half of the coil plug, leaving the other side open, is that right? and could this really cut down on my times...guess I found most of my stumbling problems...
Old May 24, 2006 | 10:57 PM
93yellowta's Avatar
Re: went to track not happy..
anyone any ideas..
Old May 25, 2006 | 07:02 AM
ZMaster's Avatar
I think you already answered your own question, ie, the wires. Cut a new set and throw them on there and giver her another go.
Ian
Old May 25, 2006 | 08:31 AM
chrism400's Avatar
Well,
Don't get too discouraged. At least you found a problem. I'm not a big fan of trim to fit wires. Get those right, and then get a tune. When I did a cam/header mod, I picked up only .1 in the quarter and 2 mph. The new tune gave me .6 and nearly 6 more mph. It was huge. You have alot of go fast parts, and you will be fast with a little perseverance .
Old May 25, 2006 | 11:41 AM
vin1382's Avatar
what is your shift point in that auto 93. you cant change shift points in the auto without changing the springs/weights. so its shifting at the stock location, and thats with a cc306.
Old May 25, 2006 | 03:13 PM
1racerdude's Avatar
What gear and what shifting pounts?
Ya gonna have to take it to 6500 to get the cam to work.
Old May 25, 2006 | 03:36 PM
chrism400's Avatar
Huh?
Old May 25, 2006 | 04:50 PM
madwolf's Avatar
Originally Posted by chrism400
Huh?
700R4. He should be shifting at 6800ish to get good times out of it, besides figuring out the other issues. Either manually or through governer adjustment.
Old May 25, 2006 | 05:37 PM
93yellowta's Avatar
I am manually shifting it at 6,000 rpm's..scared to take it too much higher on stock bottom end...what would be a safe rpm to take it to?
and also found out that my tune is alittle off. did a search on cam surging and pulled up some good stuff. the cam is causing overlapping of the valves, I think I got that right, and it is freaking out the 02's at idle, it is showing a false lean which in turn is dumping more fuel, I am really running pig rich at idle.. can smell the raw fuel. last night I opened up the hood and saw a light show. so today I replaced the wires, new coil wire, and found out the coil wasn't grounded to the frame, I put on a new 4 guage ground to it and the frame, that took out about 50% of the stumbling/surging. still have alittle surge, once I get the tune straightened out, and my rr's adj. they need adj. pretty good, I should do much better...
Old May 25, 2006 | 06:01 PM
speed_demon24's Avatar
If your too scared to rev over 6K on the stock bottom end, the CC306 is the last cam you should have chosen to. To get any decent gains out of if your gonna have to shift at 6800+.
Old May 25, 2006 | 06:23 PM
93yellowta's Avatar
what is a safe rpm to shift at with stock bottom end with some miles on it, just don't want to spin a bearing or blow the bottom end...
Old May 26, 2006 | 09:35 AM
vin1382's Avatar
depends on how many miles your engine has on it, how well it was taken care of, luck, etc. mine is shifting at ~6400 rpms with the 224/230 cam in it. to get optimal power from your cam, you really need to shift it higher then that. if your not going to shift it higher then 6000 rpms..then you'll never run good times even if you get your car running perfect.
Old May 26, 2006 | 09:49 AM
Alvin@pcmforless.com's Avatar
Honestly, why don't you get it tuned? Just because it has a old tune for a different setup doesn't mean it will work with the new.
Old May 26, 2006 | 09:59 AM
Javier97Z28's Avatar
Moderator
This post FTW.
Seriously.. cc306 and won't shift over 6k? Sorry, wrong cam choice there.
You guys have got to do some research before throwing "what everyone else has in there"... seriously...
Shift the bitch at 6700 rpm until she blows up.. start saving for a shortblock. Or just put a smaller cam back in.. the CC503 sounds ideal for you.
Old May 26, 2006 | 12:37 PM
LT1Squirrel's Avatar
+1.
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
