Went to track and car is garbage
Old Dec 4, 2006 | 02:21 AM
  #31
Zepher's Avatar
My old 96 Trans Am M6 with bolt ons with stock 3.42 gears was running 13.4@106mph with street tires (over 200K on the stock motor).
2 of my friends with 96 Trans Am's, M6 stock, and A4 with 3.73's were running 13.6 all day long.
The A4 guy is Quickshot Kimber here on the boards.
I'd be upset if I ran those times with a cam.
But, if you are still running the stock 93 ECM, then you definitely need to dyno tune your car since Speed Density is not mod friendly, you HAVE to tune the car when major mods are done.
Old Dec 4, 2006 | 07:50 AM
  #32
Sweetred95ta's Avatar
It's not the times that I'd be worried about, it's the 101 mph trap speed. My car, along with pretty much everyone else's, ran faster than that with bolt-ons. You need to check the simple things (ie. rockers, lifters, plugs (to see if the car is running rich or not), ect.)
Old Dec 4, 2006 | 08:00 AM
  #33
Javier97Z28's Avatar
Moderator
Originally Posted by Heatmaker
Those times didn't sound that bad on a 87k car with those addons. Your cars 1sec less than stock. You should have it dynod, and that hsould give you your answers. Better than wasting money playing guessing games as to what needs to be done.
A hotcam car at the slowest should be going at LEAST mid 12's. If it's not, something is wrong.
Sounds like the original poster has a mystery car, with mystery mods, and a failing transmission.
Old Dec 4, 2006 | 08:30 AM
  #34
I would say you were correct, but I'm pretty sure (with 2.0 60 ft times) that he doesn't have a stall. I ran 12.85 @ 108 w/ 2.0 60 ft. w/out a stall and 12.28 @ 111 w/ 1.75 60 ft with one. Those times were with the hotcam kit.
Old Dec 4, 2006 | 09:21 AM
  #35
Moderator
I probably should change my post and base it off MPH.. but obviously your MPH was there when you first went out, so it was ok too
Old Dec 4, 2006 | 09:29 AM
  #36
T/A-Bob's Avatar
I also think a car with those mods should be doing better. I'm running 13.68 @ 100.4 with stock heads, stock cam, stock exhaust (including cat back), stock suspension, stock A4, stock tune. (The Corsa was added after my last time at the track.)
Old Dec 4, 2006 | 06:14 PM
  #37
MeanGreen97Z's Avatar
A stock LT1 would trap 99-102mph depending on transmission and rear end gears. His mph is definately a cause for concern and my whole reason for posting.
Old Dec 4, 2006 | 06:23 PM
  #38
JakeRobb's Avatar
Super Moderator
You should be able to get a better 60' time with Nitto drag radials. Are you doing a burnout?
Old Dec 4, 2006 | 07:30 PM
  #39
Hawk's Avatar
Wait, I didn't see that you had a hotcam.
Let me edit my previous post and say you should be running faster then 101 trap.
I ran 101 trap with a stock motor and just boltons.
Old Dec 4, 2006 | 10:41 PM
  #40
Craddock's Avatar
Originally Posted by Lt1Demon
I wish I knew why I had to shift it manually. If I floor it in D or OD, The car will rev up to like 3800, instead of reving higher, it will sit there and then upshift. I did have my tranny built earlier this year and he said whoever had the car before me, put in "half of a shift kit" and that I have a "higher end torque convertor". I would have aske dhimw aht he emant but my dad was talkign to him when he told him all of this.
I had my transmission rebuilt and I know it has a shift kit, and upgraded internals but a close to stock torque converter and it shifts according to how much gas I'm giving it. When I floor it though it goes all the way to redline.
I hope you didn't pay too much for it because it sounds like they promise you a built monster and you got shafted.
Old Dec 5, 2006 | 09:58 AM
  #41
ZFan88's Avatar
Damn that's off. My vert ran a 13.4 at 104 with intake, headers to a dumped ory...that's with a 2.18 60'
Old Dec 5, 2006 | 11:24 AM
  #42
ABA383's Avatar
I can't believe anyone would run the car with metal shavings in the oil...He also is basing the Hot cam on hearing it run...I hope his ears know what they are doing...By no means am I trying to be an ***, but you really need to find out exactly what you have and fix whats broken before you can compare anything...Don't take anything as fact until you prove it yourself...If Ed tuned it, he may have records of the car or previous owner, etc including the mods...Back track and investigate to find the truth...
--Alan
Old Dec 5, 2006 | 11:25 AM
  #43
Lt1Demon's Avatar
I'll go back to the track after I get my new rocker arms on and see if that helps any. I'll also checked the spark plugs and if needed, get new ones. I'll probably gaet a dyno tuen after and see how much all this helps. Few questions though.
1. Any better than other spark plugs to use, or they all basically the same?
2. Since car is a 93 and can only be tuned through a chip, would they be able to tune my car at a dyno shop?
3. If they can tune my car, Any one know where there are any dyno shops in Orlando?
Old Dec 5, 2006 | 11:46 AM
  #44
1. The plugs are personal preference. Many people are happy with NGK's. I run Autolites.
2. Yes. It's actually easier, because the tuner can use a 'real time' tuner and make all the changes to see what works, before burning a chip.
3. Can't help you with this one.
Old Dec 5, 2006 | 11:57 AM
  #45
mthegodfather's Avatar
Originally Posted by mdacton
me and several others ran hot cams back in the day and we all ran low 12's on stocks heads tune etc... I even ran stock rockers and springs and went 12.0's
You need to sit down...go through it...see what you got and descide where you want to go.
What do you want to run? get a new set of springs, check pushrod length, get some rockers, gear tires, 93...sounds like your t.v. cable is out of adj. put a servo in the trans check the fluid....
Just go through the car and do what needs to be done....If you want it to run right you have to put the time into it. To me sounds like you bought somebody elses problem, they got tired of messing with it
take it one step at a time and everyone is here to help
Don't be mad at a bad track time...car has a lot more in it trust me
Nice advice.
Feffman
Oct 9, 2015 05:42 AM
Louey
Pacific
Dec 25, 2014 03:27 AM
Louey
Pacific
Dec 8, 2014 08:01 PM
Louey
Pacific
Dec 1, 2014 04:16 PM
USAirman93
Nov 24, 2014 03:37 PM
