Went over speed bump and engine died...
Old Jul 2, 2004 | 06:39 PM
Kurt Crosbie's Avatar
I tried to crank it up a few times and failed. I waited a few minutes and it cranked right up. Then I went through a few huge puddles (it was raining quite heavily) and it cut off going through one. Again, I tried to start it up and it wouldn't. Now I'm stumped and stuck.
Old Jul 2, 2004 | 07:08 PM
LREFLYBYOU's Avatar
do you have a cold air intake?Is it the SLP style?Is your splash guard off?Did water get in your engine?The bump problem,did you scrape?Did you smash ur oil pan against the bump?Did you loose oil pressure?
Old Jul 2, 2004 | 08:22 PM
)2overt SS's Avatar
Re: Went over speed bump and engine died...
It died going through a big puddle? Sounds like Optispark to me
But died going over a bump? Well now, that's a new one for me...
Old Jul 2, 2004 | 09:24 PM
94 CAMRO Z28's Avatar
As far as dieing going over a bump, I would think that means a bad connection on either your battery or coil. Both would be easy to test and fix. Dieing when going through a large puddle usually points to the optispark. I haven't had trouble with this before but have read of it happening often enough.
Aaron
Old Jul 3, 2004 | 10:58 AM
Formula_one's Avatar
I'd check your intake for water... then the coil.. battery and then if it still doesnt run, then most likely it's the opti.
I hope you didnt suck up any water, though.. That could be bad, could.
Old Jul 3, 2004 | 12:10 PM
Heatmaker's Avatar
Advanced Member
I fouled up going in a deep puddle too... but the water shorted out my MAF unit.... and caused my car to die... Didn't act right till I cleaned it off...then she started right up... check that...
Old Jul 3, 2004 | 02:14 PM
Well, it ended up starting right back up. I guess something just needed to dry off. I don't have a cold air intake, its the factory one. I agree with the optispark idea because when I went through another puddle/bump, it tried to stall again, but I stayed on the gas and it came back to life.
I'm wondering if a mount has anything to do with this. One of my mounts is bad, but I can't figure out wich one. I get a clunking coming from right under my feet to the right. When I go over any bumps its more of a rattle.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
siguy
Nov 27, 2014 10:07 AM
