Went to the dyno tonight, not really sure what to think.
Old May 24, 2007 | 08:43 PM
ChevyTuffD.A.'s Avatar
Here's the numbers. Temp around 80 degrees. Humidity around 50%
max HP: 296.48
max TQ: 304.29
SAE Corrected
max HP: 484.87
max TQ: 496.54
The motor was heat soaked from the very start. I will try and get the sheets up ASAP. I dont really know what to think. I was kinda thinking this was a little on the low side with the mods I have. What exactly does SAE corrected mean and does it really have any significants? The operator said my A/F was even at 13 all the way across. If you guys could give me your full input I would appreciate it. I got a vid also that I will get put up soon. Thanks. Dustin.
Old May 24, 2007 | 08:56 PM
JAB's Avatar
JAB
I'm going to go out on a limb and say your corrected numbers are a little off. SAE corrected is normalizing the numbers so that they can be compared to all other numbers regardless of conditions.
Old May 24, 2007 | 08:58 PM
I was kinda wondering about that. Thought that seems kinda un-realistic, wasnt really sure what to think tho.
Old May 24, 2007 | 09:12 PM
Here is a link to one of the graphs. I know it isnt good at all but I had to take a picture of the graph with my camera. But it might give you some sort of idea what its doing. I will try and scan the graph as soon as I get a chance. Thanks.
http://viewmorepics.myspace.com/inde...mageID=9149575
Old May 24, 2007 | 09:31 PM
'94 Bad A Z28's Avatar
There is no possible way. Go to a different dyno.
Old May 24, 2007 | 09:36 PM
Are you refering to the SAE corrected numbers??
Old May 24, 2007 | 09:38 PM
yes
Old May 24, 2007 | 09:42 PM
I understand that the corrected numbers are way out of wack. But by looking at the lines on my graph, do I have some major issues that need fixed?? I looked at a few other graphs of other members cars and there graphs are nice and smooth. Mine are all over the friggin place.
Old May 24, 2007 | 09:44 PM
89TramsAmGTA's Avatar
What was the barometric pressure? I can't get to the graph from your link. Also was the converter locked or unlocked?
I agree with the above. Ignore the SAE numbers.
You have to log in to myspace to view the pic and I really don't feel like going on myspace at the moment.
Old May 24, 2007 | 09:54 PM
Sorry about the Myspace thing. Its the only place for me to post the pic right now. My dyno sheet says the pressure was 19.36 in-Hg. If thats what that means.
Weather.com says the pressure right now is 30.36, but I dyno'd about 2 hours ago.
Old May 24, 2007 | 09:56 PM
www.photobucket.com
Old May 24, 2007 | 10:01 PM
http://s198.photobucket.com/albums/a...Picture074.jpg
there ya go
Old May 24, 2007 | 10:02 PM
seawolf06's Avatar
Short answer, YES. That graph is not smooth at all. There's definitely something wrong. Check your fuel first, then maybe ignition.
Old May 24, 2007 | 10:20 PM
JAB's Avatar
JAB
X2 , there is no way it should be anywhere near that wavy.
