Well im half way done with my header install.
Old Mar 6, 2004 | 06:08 PM
pntballty's Avatar
Thumbs up Well im half way done with my header install.
Like it says half way done and boy am i glad!! Removing the old exhaust was a major pain in the ***. Luckily no twisted bolts or anything of that matter. So tomorrow morning i will begin installing my Jet Hot LT's. Do you guys have any tips for the install? Wich was the hardest part for you? Installation of the new headers, or removal of the stock exhaust? Btw im going with true duals so no worring about a Y-pipe fitting up. Thx guys, Tyler
Old Mar 6, 2004 | 06:12 PM
MauriSSio's Avatar
i think taking off the stock parts will feel like cakewalk once you really get in there and try to install the headers..................good luck............
Old Mar 6, 2004 | 06:19 PM
showtime89's Avatar
Last bolt on the passenger side SUCKS. Also, I didn't have my car up high enough, so I had to jack the engine up to get the passenger side header tube in. That and I had to mash the two wing things on the stearing shaft otherwise it would have hit the #1 tube.
Old Mar 6, 2004 | 06:20 PM
pntballty's Avatar
Ok thx for the info, im using stage 8's so hopefully the bolts will be a little easier since i can use an allen wrench also. Anything else? Thx Tyler
Old Mar 6, 2004 | 06:47 PM
My95Z's Avatar
taking off was so easy!!! going in really sucks... I had to jack up the motor a bit to get the passanger side in. I eventually got it, took a while tho
Old Mar 6, 2004 | 08:04 PM
Robbie's Avatar
If getting the headers in there start to drive you crazy dont be afraid to jack the engine up. Helped me a ton. The passenger side slides in fromt he bottom without jacking the engine up or removing the starter. At least it did with mine. I have Hooker LT's btw. Probably not much difference. Good luck and your gona love them. Especially after you race an LS1 with them on, hehe. Wakes the LT1's up big time on top-end.
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
Russ95Z28
Apr 23, 2015 01:55 PM
thenewkid
Nov 18, 2014 12:57 PM
94redform
Sep 8, 2002 03:27 AM
