We'll I'll be....
Old Dec 9, 2004 | 01:04 PM
"White Knight"'s Avatar
We'll I'll be....
So today i read a post and see that you can't use a cloyes doubble roller chain on my 94. I hadn't realized it until now. It sucks....i was just going to do my electric water pump install this winter and now i realize i can't use the timming chain i wanted.
I WANT A TRUE ROLLER CHAIN FOR THE 93 and 94's!!!!
Old Dec 9, 2004 | 01:20 PM
QUASARBLUEZ28's Avatar
Re: We'll I'll be....
Sure you can,,,just need to do a few more "well worth it mods". I wouldn't mod around an 80$ roller chain but the overall conversion to a Vented OPTI, hotcam and dbl rller chain is, along with the Electric Water pump. Just start collecting parts and shoot for the spring time.
EDIT: Just saw you run the Delteg. in you mods list. Lets think about this. You are a 94 that ran the non vented opti
and the splined driven opti prior. You must still be running the non vented opti unless you upgraded to a 95 and a veneted system.
Fact is the cloyes roller will not work with the 94 timing cover, so it would need to be a 95-97 cover to use that chain. The 95's were pin driven to the optis which were vented.
Your upgrade now uses a CPS to fire the plugs with the Delteg I assume. With a hotcam and extended pin I would think you would be good to go with a 95-97 cover ,veneted opti and make use of the cloyes setup.
Maybe I'm missing something here, but you should be able to get everything to work.
Old Dec 9, 2004 | 01:43 PM
not after you spent 600 dollars on the delteg system. I guess i could get one from a fellow board memeber that is bad maybe....
Old Dec 9, 2004 | 02:25 PM
Mikey97Z's Avatar
The HD LT4 set is a Cloyes True Roller (single not double)
Here they are with a stock chain too
http://z28.reanimator.org/pics/timing_chains.jpg
EDIT: Sorry, I guess it's not spline driven.
Old Dec 9, 2004 | 02:45 PM
ibanez6rg's Avatar
I use a Cloyes True Double Roller on my 94.
Old Dec 20, 2004 | 01:20 PM
yea with an opti converson^
Chet1185
Parts Wanted
Feb 14, 2013 11:14 AM
Brangeta
Aug 23, 2011 09:38 PM
20TEN_SS
Jan 31, 2011 11:17 AM
Kayser13
Oct 22, 2010 07:33 PM
Bishop94
Aug 27, 2008 07:47 AM
