Rattling noise coming from in or around my catalytic converter
Old Dec 18, 2004 | 01:52 PM
SPEEDYGUN's Avatar
I have this rattling noise coming from in or around my converter. At first I thought it was a loose fitting on my exhaust somewhere, but today when leaving work it was louder. I narrowed it down to the catalytic converter (or the surrounding area) and I was wondering what could be causing it?
Old Dec 18, 2004 | 01:58 PM
SnakeSkinner28's Avatar
Re: Rattling noise coming from in or around my catalytic converter
Its either the heat shield on the converter making noise or the cat has broken up inside. Take a big screwdiver and hit the cat and listen for noise from the inside to tell if there are broken pieces. I would just gut it if you can and then you can take the heat shield off.
Old Dec 18, 2004 | 05:02 PM
CamaroSS30thAnn's Avatar
what he said
Old Dec 18, 2004 | 05:54 PM
350jeep's Avatar
Would gutting the cat, so that it doesnt function anymore, adversely affect the way the car runs (other than helping exhaust flow), if so, how? If it doesn't affect the car, what is a good way to gut the cat (run a drill bit through, stab at it, etc.)?
Old Dec 18, 2004 | 11:16 PM
Sevendustx1's Avatar
Wouldn't affect drivability. You'd probably see little torque lost But a small increase of HP. Best way to gut it. Cut 3 sides around the cat. Pry it open, Chisel away, and Weld it back up.
Old Dec 18, 2004 | 11:36 PM
Hell no, take the cat and ypipe down from the exhaust system and take a pry bar and hammer and break up the insides of it and dump it out. Take ya about 20 minutes and make sure you dont breath the dust from it. And you will notice a pretty big increase in power once its gutted. Least i did.
Old Dec 18, 2004 | 11:46 PM
SPEEDYGUN's Avatar
Why would you gut it and put it back on instead of just removing it all together?
Old Dec 19, 2004 | 12:52 AM
Flmac02Z's Avatar
or you could get higher flowing cats
~Kevin
Old Dec 19, 2004 | 02:23 AM
LMAO. The cats are welded to the y pipe! If he takes the y pipe down tell me what "Pry Bar" is he going to use to break up the insides If it has a curve? On an Ls1 with dual cats. The cat on the driver side has flanges it can unbolt from the y pipe. That cat can be gutting like you described. However the passenger side can't be gutted that way because its one with the y pipe and the curve gives you no access. I believe this design goes for lt1 OBD II cars as well if im not mistaken.
Old Dec 19, 2004 | 06:57 AM
You laughed your *** off, really? Its not that funny if you dont know what your talking about, or your trying to make your self sound smarter by making me sound wrong. First of all, since he was posting in the LT1 section i was assuming thats what motor he had, so therefore who gives a damn about an the exhaust setup on an LS1. My only mistake was assuming that he had a single cat setup, but given the way he spoke about "noise from the cat" not noise from the cats, or noise from the left or right cat, i thought it was a pretty safe assumption. Therefore, on a 93-95 SINGLE CAT SETUP, he CAN unbolt the Ypipe from the manifold, unbolt the cat from the intermediate pipe, take the cat and ypipe off the exhaust and then take a prybar and break up whats inside. And of course the cat is welded to the ypipe, thats why you take it down in all one piece, and gut the cat through the BIG OUTLET HOLE. I simplified it as much as i could for you. So please tell me what part of what i just said is wrong. Jackass.
Old Dec 19, 2004 | 09:41 AM
That way it saves you the cost of an offroad pipe, and the time to put it on. Also incase you ever get pulled and the cops for any reason look under the car you still have a cat in place. In a lot of states if you illegally gut the cat that can lead to big fines. And high flow cats still do not flow as well as a gutted cat, i dont care what you say.
Old Dec 19, 2004 | 10:59 AM
SPEEDYGUN's Avatar
Thanks for all the info guys. because of the potential fines and emission test problems, gutting it doesn't look like a viable option, so a high flow cat looks to be the way to go.
I have a 97 LT1, so do I have 2 cats? The one that is bad is the one located under the front passenger seat. Can I just replace that one and leave the other alone?
Also, I have seen people mention the carsounds cats on ebay. Is this the cat they are referring to? $60 bucks shipped
http://cgi.ebay.com/ebaymotors/ws/eB...941864000&rd=1
I need the 3" cat right?
Old Dec 19, 2004 | 11:09 AM
djfuzzy's Avatar
I have a noise like this as well. I thought it was coming from around the shifter. It makes the noise at lower RPMs. I thought my shifter was loose so I tightened it on real good. It is coming from the right side of the tranny, so I suppose it could be my cat making the noise, guess I will have to take a screwdriver to it...I was going to gut it anyway.
Old Dec 19, 2004 | 02:58 PM
TobyZ28's Avatar
My cat's doing the same rattelling. IT definatly sounds like the cat or something very close to it. It started doing it ever since my new Cat install :/ Wish i could find a way to fix it.
Old Dec 19, 2004 | 05:11 PM
yup u have two cats , one tuck up on teh left side (driver) that looks like a coffee can and the other is down lower inder the passenger side seating area looks like a normal catt,.
