Welding onto an oil pan
Old May 18, 2004 | 09:00 AM
Rodrigues's Avatar
Is it safe to weld onto an empty oil pan while its on the car? Empty as in, has oil residue inside the pan... This may be a stupid question, im not sure.
Old May 18, 2004 | 09:44 AM
Gripenfelter's Avatar
Yeah...not a good idea.
Take the time to pull the two engine mount bolts out and lift the engine up so you can unbolt the pan and remove it.
Old May 18, 2004 | 09:50 AM
Rodrigues's Avatar
Is oil combustable? Ive never really though of oil as a highly flammable substance but who knows what it could do in a confined area...
Old May 18, 2004 | 10:41 AM
You know how people mix oil and gas together to make Molotov cocktails?
Yeah.
I would say don't try but if you do make sure you take pics of the aftermath for us.
Old May 18, 2004 | 11:47 AM
Rodrigues's Avatar
Lmao, can i get another opinion!!!!
Yeah.
Old May 18, 2004 | 12:09 PM
I don't think it would be worth the risk of doing it with the pan on. It is the vapors that become explosive.
Now, if you were like this guy, it probably would not bother you.
Old May 18, 2004 | 01:59 PM
Rodrigues's Avatar
LMAO!!!!!
Old May 18, 2004 | 02:30 PM
Brent94Z's Avatar
Super Moderator
At least he is using a rear tire wedge
Old May 18, 2004 | 02:37 PM
Josh-'04 GTO's Avatar
Hilarious!
Old May 18, 2004 | 11:19 PM
pappasmerf18's Avatar
oil takes a lot of heat to burn up but to bee safe i would take it off. just for conversation why do u need to weld the pan for.
ryan
Old May 19, 2004 | 01:01 AM
ZBLKHELLRZR's Avatar
Maybe he's looking to weld a bung for a sensor or something. That's what I was going to do but since looking at this I just may reconsider.
Old May 19, 2004 | 09:15 AM
Rodrigues's Avatar
I need to weld on a fitting for the oil drain on the passanger side turbo for a second scavenge pump...
Old May 19, 2004 | 09:25 PM
Rodrigues's Avatar
I dropped the pan enough that its pretty well ventilated, I would expect for a small fire to start, but nothing major that I couldnt blow out, any ideas?
Old May 19, 2004 | 09:32 PM
I assume you drained the oil. Cram a big wet towel in there.
Old May 19, 2004 | 11:57 PM
Rodrigues's Avatar
Good idea, im just going to punch a hole, weld a nut on then use a NPT fitting to screw into the hole. Should be pretty simple to weld too... If I stop posting after tommorow check the news.
