top throttle body gasket?
Old Apr 2, 2004 | 11:46 AM
sabre81's Avatar
im wondering about the importance of the top tb gasket. If mine is all dried up and beat up is it worth replacing? Can it cause problems? Where can i get one?
thanks
Old Apr 2, 2004 | 11:53 AM
You don't want that gasket to leak... that chamber is located between the air inlet port in front of the blades, and the port on the side of the TB for the hose to the passenger valve cover. The gasket comes in a "kit" with the one for the bottom plate. Shoebox has the kit part # on his website. There is really no reason you couldn't make one out of a sheet of rubber. You only need to cut a simple rectangle.
HectorM52
Jul 30, 2017 11:46 AM
Fatdog2
Feb 13, 2015 08:19 PM
Queens94z28
Dec 20, 2014 09:11 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
