weld on relocation brackets
Old Apr 1, 2004 | 05:43 PM
bowtieman_racin's Avatar
Exclamation weld on relocation brackets
Any one have good instructions or ideas about welding on lca relocation brackets? Should I jack the rearend all the way up, let it down? I dont know how to be sure they are even or in the right place. Any help is greatly appreciated. thanks,
Old Apr 1, 2004 | 06:02 PM
DrivinSidewayz's Avatar
position your rear end so your LCA is lined up with the stock bracket hole, then you can arc your LCA down and line up the bracket so that the dropped holes are within the arc of the LCA moving down from the stock hole, then clamp the relocs in place, tac them on. then remove the clamp, then fully weld. with the weight of the car on the rear axle would be best
Nayr
Mar 3, 2023 08:34 PM
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
War Engine
Sep 18, 2015 07:28 PM
Boss002
Jul 24, 2015 10:47 AM
