Weird Vibration around 4000 rpm.
Old Nov 30, 2003 | 12:00 AM
xxsaint69x's Avatar
Ok, this has been bugging me for long enough
Have a nice little vibration around 4000 rpm and it’s gone by around 5000. Happens in gear or in neutral. Moving or not.
Stuff that i have.... Poly tranny mount, and tq arm mount.
Street Twin with a steel flywheel.
What can be causing the damn vibration? I don’t think it can be a flywheel? Everything is nice and smooth till 4k and then it vibrates and it’s gone by around 5k. What should i start checking?
The vibration began after I put the street twin in.
Marcin
Old Nov 30, 2003 | 10:20 AM
xxsaint69x's Avatar
ttt
Old Nov 30, 2003 | 10:34 AM
95 Z/28 LT1's Avatar
Super Moderator
Have you checked your motor mounts?
xxsaint69x's Avatar
hmm good idea
Will i be able to tell just by looking at them?
Marcin
Old Nov 30, 2003 | 10:42 AM
Super Moderator
Usually if they are bad they will be distorted badly or ripped.
Old Nov 30, 2003 | 10:49 AM
MYT30TH's Avatar
Re: Weird Vibration around 4000 rpm.
Marcin
Marcin,
I have the same thing ( after the ST install), and it's been bugging me also......I have a new tranny mount, new u-joints( rotated shaft 180*), and even put in a new tail-shaft bushing in , and its still there
I'm thinking it could be the Street Twin
Old Nov 30, 2003 | 10:55 AM
xxsaint69x's Avatar
did you check the motor mounts?
i am going to check mine in few....i hope thats the problem.
Old Nov 30, 2003 | 08:56 PM
MYT30TH's Avatar
I think when I was checking every other thing .... that was on my list .... but I'm going to double check the mounts tomorrow to be sure. ( I even took a look at the balancer, and that looked good ) I keep you posted .
Old Dec 3, 2003 | 09:57 AM
Super Moderator
Well, what did you come up with?
Old Dec 3, 2003 | 09:12 PM
xxsaint69x's Avatar
they look fine....What should we do?
Old Dec 4, 2003 | 11:47 AM
Super Moderator
Did you look at your harmonic balancer?
Old Dec 4, 2003 | 01:37 PM
MYT30TH's Avatar
Checked the motor mounts, and they look good......I had looked at my balancer before and it looked good as well.........
Old Dec 4, 2003 | 01:45 PM
xxsaint69x's Avatar
i am fixin to call them..will post results in a min.
blah...they are closed til the 8th due to some show.
Old Dec 13, 2003 | 02:09 PM
xxsaint69x's Avatar
ok here is the solution to the problem. I finally got in touch with Mcleod and their tech told me that i should turn the pressureplate 2 bolts over to fix the problem or to take the whole assembly and get it rebalanced. He said turining the pressure plate over 2 bolts will most likely fix the problem thou.
Marcin
Old Dec 14, 2003 | 08:56 AM
Super Moderator
Make sure you let us know how that works for you.
