weird sound comming from tranny(m6) when press the clutch its gone???
Old Apr 15, 2003 | 04:36 PM
cridom's Avatar
i saw my trans mount and it looks fine and also when i go on reverse i hear a click? y? maybe its the mount but how do i know its bad?
thanks
Old Apr 15, 2003 | 04:51 PM
norcalstreet's Avatar
Sounds like the throw out bearing. If it rattling that's normal. Besides the "click" you hear when putting it into reverse does it present any other problems? Hard shifts?
Old Apr 15, 2003 | 05:01 PM
cridom's Avatar
reverse is tricky some times
can i fix all this myself and for cheap?
Old Apr 15, 2003 | 05:30 PM
cals400ex's Avatar
i think most of the money will be in labor charges. i am debating whether i want to drop my tranny myself or not too. by the way, yours needs to come out to replace the throw out bearing. i don't have a tranny jack and i don't know what exactly i am doing. the bearing can not be too expensive. i am not promising you that the bearing is your problem but its very possible. i actually think one of my clutch springs broke. reverse for me has always been tricky. sometimes it doesn't want to go all the way up and then you will hear a grinding if you let out the clutch. good luck
Old Apr 15, 2003 | 05:57 PM
cridom's Avatar
i hear the same noise from reverse sometimes not too many though
im a newbie can u explain all i need to do?
mattszm6
Dec 14, 2014 07:09 AM
NewsBot
Dec 3, 2014 12:30 PM
siguy
Nov 27, 2014 10:07 AM
Snoman73
Nov 17, 2014 07:22 PM
jmzlt1
Mar 13, 2003 07:26 AM
