Weird rattle
Old Aug 20, 2003 | 02:45 AM
neil350's Avatar
Weird rattle
On smooth roads the car is dead quiet, but going over rough roads it makes a weird ratling noise from under the car. Started after I got a Vigi 3200. Now, its just a noise and the car has no vibrations and some times wont even make the noise. As far as the way the car runs, it runs awesome, no complaints. It was a little weird driving it after the converter but the car runs and drives fine. Its not leaking any trans fluid at all.
Old Aug 20, 2003 | 01:01 PM
neil350's Avatar
TTT
Old Aug 20, 2003 | 01:05 PM
speedmiser's Avatar
Have you checked the TC bolts and the pan cover screws???
Old Aug 20, 2003 | 01:10 PM
neil350's Avatar
Pan is on tight, I dont think the converter is loose because the noise is intermeitten and I cant feel any vibrations from it. Joe rode in it and he doesnrt think the converter is loose.
Old Aug 20, 2003 | 02:28 PM
JBirdSS's Avatar
I have a driveshaft loop on my car and it was hitting the body for quite a while before I figured it out. Look at anything that could hit the body like the Y Pipe or connections from suspension items like the panhard bar. If it is hitting only on bumps sounds like something else other than a tranny problem...more like suspension or exhaust.
Old Aug 20, 2003 | 04:22 PM
neil350's Avatar
Talk to the shop and were thinking it may be exhaust. Tomorow I'm talking it to the shop that did the converter install, its a banging noise, does it on rough roads and on the freeway. Its some thing vibrating and making noise.
Old Aug 21, 2003 | 12:44 AM
Cmr0z28's Avatar
inspection plate?
Nayr
Mar 3, 2023 08:34 PM
autoxr166
Sep 25, 2015 04:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
