weird question...
Re: weird question...
For starters, take out both of your reverse light bulbs and look at them. What you will probably find is a broken filament that fell and shorted across the input wires causing enough current flow to blow the fuse (and not light up). If this is the case, replace the bulb-actually, better to replace both at once. If it blows the fuse with the bulbs out, start looking for frayed insulation on wiring.
Nayr
Mar 3, 2023 08:34 PM
