Weird Problem, help if ya can...
Old Oct 19, 2003 | 03:49 PM
camaro681's Avatar
Hey my car started having this weird problem lately, and I'm not sure whats causing it. When I go to start it, it starts then automatically dies. It'll do this once or twice then it starts up and has a SES light, not sure what code. Anyone have any advice?
Old Oct 19, 2003 | 04:18 PM
Phatcaprice's Avatar
You'll need to pull a code from it, but the symptoms, sounds like a TPS of MAF sensor failure. And check for fuel pressure! Good luck.
Old Oct 20, 2003 | 09:42 AM
camaro681's Avatar
Well, I know it's got fuel pressure. I'll have to go get it checked out at my friends house.
Old Oct 20, 2003 | 12:19 PM
RENE95Z's Avatar
Possible suggestion: may be your IAC acting up. Take it out and clean it up. To reset the IAC after putting it back in: press the gas pedal slightly, then start your car and hold the pedal for about 5-10 sec. Shut the car off and wait about 30 sec. and then start up again.
Old Oct 20, 2003 | 06:07 PM
TArider21's Avatar
Exclamation weird problem
Sounds like its your maf, when my maf was acting up, my car did the same thing.
timmy39120
May 8, 2015 11:41 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
