Weird Complicated problem
Old Jul 5, 2008 | 10:05 PM
bds001's Avatar
Hey guys, I've got a wiring/lighting issue I was hoping somone could help with.
Whoever had the car before me, I'm guessing the brake lights went out on him. Whoever tried to fix it for some reason spliced into the power wire leading into the hatch brake light. They then proceeded to run that wire into the brake lights so that they can run lights. The problem that I have is that with the way they did it whenever I press on the brake while the tail-lights are on the light barely gets any brighter. Any ideas on what I should do to fix it? I'm not sure if it makes it to where the brake lights are always on or if it just doesnt get hardly any brighter when I press on the brakes.
Also, whenever the lights are turned off and you press on the brakes, for some reason the dash lights light up.
It's a 96 Z28
Thanks for the time!
Last edited by Injuneer; Jul 6, 2008 at 10:20 AM. Reason: Post only on correct forum. Brakes lights don't belong on LT1/LT4 Engine Tech. Already posted on "General...."
timmy39120
May 8, 2015 11:41 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
Magenta_Hearts
Mar 5, 2015 07:01 AM
InfernalVortex
Jan 17, 2015 09:35 AM
97z28k&N
Jan 9, 2015 04:58 AM
