weak showing
Old Dec 11, 2006 | 06:27 AM
  #16
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Same numbers and mods as I have in my sig i put down 25rwhp less on a mustang dyno. They put the car under load and the dynojet doesnt. Good for tuning, not so good for numbers. So its a combo of your weak exhaust and numbers from a mustang dyno.
Old Dec 11, 2006 | 08:21 PM
  #17
Zachz28's Avatar
The other cars were a LS1 with a cat back that put down 315 and a stock LT1 caprice that put down 240ish.
Old Jan 5, 2007 | 02:08 PM
  #18
Zachz28's Avatar
Ok i still dont know what to do with this car. Not only did it have a weak dyno pull, but over the summer the best i ran at the track was a 13.9 and the thing has been getting progressively worse gas mileage (160 to a tank). But it seams to run fine, idle great and when i pulled it on the dyno the hp line kept climbing and and the tq curve was a nice even line just low.
Old Jan 5, 2007 | 03:07 PM
  #19
mdacton's Avatar
what brand converter is it?
you have a big issue somewhere...my friend ran that cam with shorties and no tune...he went low 12's at 112
Sounds like possibly a mechanical problem or a crappy tune
Old Jan 5, 2007 | 03:12 PM
  #20
speed_demon24's Avatar
If its a cheap restalled convertor that might be eating up some power. And a dyno tune, longtubes, and true duals will definatly help out.
Old Jan 5, 2007 | 03:43 PM
  #21
Zachz28's Avatar
What kinda of mechincal problem would cause such a power and MPG loss awhile maintaining showing no other problems
Old Jan 5, 2007 | 04:22 PM
  #22
MeanGreen97Z's Avatar
What kind of converter for the 4th time. The BBKs are pulling hp, what kind of y pipe do you have, and do you have and KR?
Old Jan 5, 2007 | 04:27 PM
  #23
Zachz28's Avatar
I have no idea what converter it is i got it with the car stall is 2500, the y pipe is bbk and no i have no kr
Old Jan 5, 2007 | 04:46 PM
  #24
mdacton's Avatar
mechanical problems
converter going out
trans slipping
valve springs
wrong push rods
bad bearing, water pump,alt, ps
fuel reg/pump
ignition problem?
what have you checked so far....things don't just bolt together and work well
its a system, everything has to be in top shap for the sytem/car to run right
With your mods and a o.k. converter I would say 325 rwhp would be a resonable goal
Just my opinion, but i'm no genius
Old Jan 5, 2007 | 05:30 PM
  #25
Zachz28's Avatar
trans is new,valve springs are new,pushrods new hardened from combination motor sports, new plugs wires cap & rotor, coil, (if there was a ignition wouldnt the hp fall of at high rpm?)
Old Jan 5, 2007 | 05:41 PM
  #26
mdacton's Avatar
i meant ignition system in general plugs wires
What do your a/f/ look like?
I have been on the dyno and picked up 30-40 h.p. b/c my fuel press was too low
could be many many things
Old Jan 5, 2007 | 05:57 PM
  #27
byrons1502's Avatar
it sounds like the combo is on the car needs an af ratio check during the run. i would say you have a different problem than not enough parts. the parts you have on are not killing it. run a scan tool on it and watch the fuel trim numbers and get the fuel pressure. the low mpg says something and so does the hp numbers.
mdacton may be right.. seen fuel filter cause great torque numbers but die at high rpm. start with the basics before you change anything
Old Jan 5, 2007 | 09:17 PM
  #28
95Z28LT1-PA's Avatar
Originally Posted by Zachz28
I just dynoed the car with the mods in my sig. and it put 267.1 RWHP and 252.2 RWTQ through a A4. Is it just me or that a little low?
That's REAL low man...I got Borla exhaust and a MSD Coil and I dyno'd 279.4 RWHP and 302.1 RWTQ
Camarokid95
Jun 12, 2015 11:25 PM
meissen
Jun 1, 2015 07:59 AM
gomaro
Events and Cruise Spots
May 6, 2015 09:02 AM
ChrisFrez
Jan 25, 2015 08:06 AM
ChrisFrez
Jan 11, 2015 03:47 PM
