stock pushrod size
Old Jan 6, 2007 | 12:01 AM
ZX636RIDER03's Avatar
stock pushrod size
i need to buy some hardened push rods cause i heard when you put a higher lift cam in you could bend a rod so i was wondering what the appropriate push rod length and diameter was for a stock lt1...
Old Jan 6, 2007 | 12:20 AM
93 4mula's Avatar
Stock length for LT1 is 7.2
Old Jan 6, 2007 | 01:56 AM
is there a particular width or diameter that the pushrod should be.
Old Jan 6, 2007 | 07:04 AM
SS RRR's Avatar
5/16 I believe. Not sure of the wall thickness.
To be completely positive you can buy a pushrod length checker and check it yourself. You would also need to put a light/stock valve spring so you don't damage the pushrod checker. However you can buy them ($35 from LPE part number ends w/ "H"), mark the top of your valve w/ a sharpie, adjust the rocker accordingly and turn the engine over several times, take off the rocker and see what position your roller bearing is on the valve tip throughout the entire sweep of the rocker on the valve tip during opening/closing. There's a thread somewhere around here w/ pics as well as a writeup I think on Comp Cams website.
HectorM52
Jul 30, 2017 11:46 AM
canbaufo
May 25, 2015 12:01 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
