We need a performance LT1/LTX intake! 2007 SEMA maybe?
Old Nov 15, 2005 | 09:22 PM
  #16
95Bird's Avatar
Re: We need a performance LT1/LTX intake! 2007 SEMA maybe?
actaully..if edelbrock or someone would just make a super victor with efi and bolt holes to fit the lt1 I would be happy. Maybe even an elbow to fit our throttle bodies with a map mount.
Old Nov 15, 2005 | 09:31 PM
  #17
SStrokerAce's Avatar
Y do you think guys like me do that? Because nobody is going to offer one out of the box...
Originally Posted by atljar
Not a hard formula here. Add runner length, add plenum.
Yep sounds like a Single Plane to me.
Old Nov 15, 2005 | 09:54 PM
  #18
fireman's Avatar
The LT1 is old enough now, it has hit the streetrod scene. That should open up the aftermarket for it all over again and then some. You can now buy a ton of speed parts or the Northstar V8 since it hit the Sandrail scene a while back. If the LT1 only had the aluminum block those sand guys want..
Old Nov 15, 2005 | 10:32 PM
  #19
atljar's Avatar
Bret Here is one for you-
Reading some mustang (blasphemy!) boards. They have been running the spider single plane intakes too. Some of them with a large single bore TB, and others with a 4 barrel carb type TB.
The guys who have done both types of TBs, have seen 30-40 hp with swapping to the carb type. To me thats odd becuase you lose all the plenum that the elbow provides. I would also think the elbow would act like a velocity stack of sorts.
Would something similiar apply to us lt1 guys?
Old Nov 15, 2005 | 10:50 PM
  #20
Fat_Boy's Avatar
Whats this MSD Opti you guys are talking about? I was told that MSD only makes caps for the opti..
Old Nov 15, 2005 | 11:36 PM
  #21
Camaro97USAF's Avatar
It's new at the SEMA show I guess.
Old Nov 15, 2005 | 11:42 PM
  #22
ChevyTuffD.A.'s Avatar
msd actually does make the full opti now, it can be purchased at advanced auto for 271 and some odd change, and it comes with a breather tube no matter if its 93-94 or 95-97, msd basicly made it a vented conversion with a few other great benifeits
Old Nov 16, 2005 | 05:36 AM
  #23
FASTFATBOY's Avatar
I think $271 was just for the cap and rotor, I dont think the full, complete opti is out yet. Look for it to be over $500, just guessing though.
David
Old Nov 16, 2005 | 10:03 AM
  #24
Fat_Boy's Avatar
Originally Posted by FASTFATBOY
I think $271 was just for the cap and rotor, I dont think the full, complete opti is out yet. Look for it to be over $500, just guessing though.David
Yeah, what he said! ^^^^
Old Nov 16, 2005 | 10:30 AM
  #25
GreenDemon's Avatar
David
The cap & rotor is $150 from summit, MSD-84811. I haven't seen the complete set yet, but MSD has been offering their stuff at the same price as OEM, so it should be less than $500.
  #26
Evil Eric's Avatar
David
i knew it was to good to be true :P
back on subject, I do think that a new intake in 'single plane' style converted for fuel injection would really sell for our motors. Look at how many new people ask questions on here about how much a gain they will see swapping to the lt4, just assuming it's a bolt up install just like going from ls1 to a ls6 intake.
Old Nov 16, 2005 | 10:43 AM
  #27
atljar's Avatar
Problem there is a single plane isnt easily made to be bolt on and go.
Even if you take a single plane already designed, you cant just change the bolt holes on it because they hit the runners. So you are already into moving runners around a touch = totally new intake. After that you have fuel rails, throttle cables, linkage, TB, etc etc to make work, and make work under all configurations of a stock hood.
Old Nov 16, 2005 | 12:28 PM
  #28
Mindgame's Avatar
I have an opinion on this as I'm sure Bret does.
I know we're placing alot of emphasis on plenum volume but as I see it, the volume is only important to a point. Where as a little more volume might help considerably, there comes a point where even more volume does nothing. Unlike a carbed setup, you can't have too much plenum volume with MPFI intake but it does reach a point of diminishing returns.
I had the opportunity to observe, measure and poke a custom built CFE LTx intake last year built to support ~600fwhp atop a 350 cid, 6-spd, 7k rpm engine. FWIW, the plenum volume was roughly 12% greater than stock.
As far as gains in HP between single blade and 4bbl type are concerned... what exactly are they swapping out? IMO, going with a single 4bbl type might be a good swap but building an intake that could take advantage of another 4bbl would probably show even more gain.
-Mindgame
Old Nov 16, 2005 | 05:14 PM
  #29
atljar's Avatar
They were swapping from a elbow and 90mm setup to a 4bbl and carb hat setup.
So they were losing plenum on theirs.
Thanks for your insight MG, and anything else you have to say
Old Nov 16, 2005 | 06:34 PM
  #30
Mindgame's Avatar
Thumbs up Re: We need a performance LT1/LTX intake! 2007 SEMA maybe?
Yeah, they probably had enough plenum volume from the intake. I'd suspect a VE loss and I bet it'd be interesting to see VE #s from that swap on an engine dyno.
Reason I asked what they were swapping is to get an idea on the size differences between the tb's. Going from a 90mm to say... a 4500 flange 4bbl type tb is sure to make a difference.
-Mindgame
