Way to test Opti and other stuff?
Well my car wont start and i'm thinking its the opti.
Is there a way to make sure before i go and blow 3xx$ on a damn opti anyways?
Also what else could i check that it might be? Its not even catching at all.
Re: Way to test Opti and other stuff?
Originally Posted by LT4orbust
Did you ck for spark and fuel pressure....not necessarilly how much pressure but if you have at least some at the valve on the fuel rail?
And i just replaced the fuel pump and it drove right after that so im sure it cant be that.
My car wouldn't start either just the other day, I made a post about it, no replies :P.
http://web.camaross.com/forums/showthread.php?t=451898
Turns out my opti is full of white stuff where the Non-spark plug wire connects to it(forgot the name, top of the opti). I sprayed some brake cleaner in there and tried to get as much of that goo out, reconnected the wire nice and good and it started right up. Of course I let the brake clean dry for a few minutes.
