Way overheating please help...
Old Jun 22, 2008 | 04:40 PM
Austin_78@msn.com's Avatar
Exclamation Way overheating please help...
so i have figured out my idle problem...but i was driving my car home and the last 3 miles it was up in the 230-260 temp range.....so after getting home, my engine was spewing smoke out and you could hear like a sizzle sound....i know its cause of my radiator but could it be a hose or something else?
oh yeah, and now i have a 1 and a half mile track down the road of coolant....
Old Jun 22, 2008 | 05:13 PM
hey01's Avatar
sounds like a headgasket
Old Jun 22, 2008 | 05:19 PM
WS6T3RROR's Avatar
Find out where the coolant was coming from first, ask questions later.
By spewing out smoke do you mean out the tailpipes or under the hood?
Old Jun 22, 2008 | 05:51 PM
If you poured a 1.5 mile track of coolant down the road, it should not be too hard to look under the car and around the engine to see where its pouring out. Check the radiator level. If its empty, fill it up with water temporarily, and warm it up to the point where the pressure builds high enough to blow the coolant out of the broken hose, cracked radiator, water pump or some part of the engine.
Old Jun 22, 2008 | 05:55 PM
under the hood
Old Jun 22, 2008 | 10:48 PM
OK.... this is like pulling teeth. WHERE under the hood.... there's a lot of real estate there.
Old Jun 22, 2008 | 11:17 PM
Sorry... the front passenger side of the engine by the alternator.
I took a look and the coolant is dripping steadily, mostly off of the drainage valve at the bottom right of the radiator.
I looked for other places it was leaking, and found none....but there was coolant over front of the engine....
Old Jun 22, 2008 | 11:41 PM
Did you try filling the radiator with water, letting it heat up to build pressure, and looking for leaks? Its probably going to spray out. Cover the Opti before you start it up.
Old Jun 23, 2008 | 12:06 AM
yeah the only problem is that as soon as i put it in, it goes right out the bottomm
Old Jun 23, 2008 | 05:20 AM
Then you should be able to see where its leaking out
Old Jun 23, 2008 | 10:34 AM
thats what im trying to say....it is coming from the drainage valve at the bottom right of the radiator but it is all over the front of my engine??
and i cant see any other places it would be leaking from
Old Jun 23, 2008 | 10:39 AM
ShownomercyZ28's Avatar
Maybe it was getting splashed over the front of the motor by the belt.
Old Jun 23, 2008 | 10:07 PM
Did you try closing the radiator drain valve?
Did you look at the coolant level sensor, to see if coolant is leaking out there? It would run down the side of the radiator to the drain.
Did you make sure the overflow hose from the radiator fill neck to the coolant reservoir was installed? That would drip down the side of the radiator to the drain.
Did you check for a crack in the passenger side radiator end tank? That would drip down the side of the radiator to the drain?
Did you check for a hole in the hoses that connects to the passenger side end tank? A leak in one of them would probably drip down on the drain valve.
damnyankee36
Sep 9, 2015 07:06 PM
Pwilson59
Sep 3, 2015 08:47 PM
Noct
Jul 14, 2015 01:18 AM
thenewkid
Jul 2, 2015 07:16 AM
Dylan Latshaw
Mar 21, 2015 09:48 AM
