Which way does the lifter oil holes point?
Old May 20, 2006 | 03:55 PM
firebirdStud's Avatar
Exclamation Which way does the lifter oil holes point?
I checked the block, and it looks like they could go either way... the GM book didn't specify one way or the other...
I ended up putting mine in with the oil holes pointing towards the rear of the motor. I figured since the oil pressure comes from the rear of the motor that they would recieve better pressure that way... Was I wrong? Or does it even matter at all? My guess is it doesn't matter, and I am just being over-**** again with this expensive peice of iron...
Old May 20, 2006 | 04:06 PM
1racerdude's Avatar
Re: Which way does the lifter oil holes point?
Doesn't matter.
Old May 21, 2006 | 09:46 AM
NOMAD's Avatar
If you notice there is a mchined recess around the lifter where your hole is, so it gets fed oil no matter which direction it comes from
HectorM52
Jul 30, 2017 11:46 AM
Spcquinn
Apr 18, 2015 09:40 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
jayblev95
Dec 1, 2014 06:55 AM
siguy
Nov 27, 2014 10:07 AM
