Waterpump removal....
Old Jan 19, 2006 | 04:16 PM
SmoothCruizer's Avatar
Is removing the fans and connectors necessary and what tools do you think i need? Thanks.... btw if anyone knows a easy simple way, (first time) I would love some pointers
Old Jan 19, 2006 | 04:26 PM
kick Z tail out's Avatar
Re: Waterpump removal....
Removing the fans will give you more room to work so you can ratchet on it... Unless you want to spend 5 hours turning box wrenches.
You'll want to have a socket/ratchet and box end wrenches.
Old Jan 19, 2006 | 05:03 PM
Dnlracin's Avatar
We just did ours this weekend and I took the radiator out also didn't wanna take a chance on hurting it too! Once you do that its a breeze. If your lucky enough to have a die grinder put the wire wheel on it and remove the old gasket its kinda hard on the right hand side not much room but it sure beats scraping with a gasket scraper!
Old Jan 19, 2006 | 05:05 PM
RamAir95TA's Avatar
I don't really scrape much anymore since I use copious amounts of gasket remover. That stuff is a GODSEND.
Old Jan 19, 2006 | 05:59 PM
OBE1 95Z28's Avatar
No need to pull the radiator. You only need to remove one fan to get clearance.
Old Jan 19, 2006 | 06:33 PM
deputydough's Avatar
basic hand tools. be careful not to drown your opti when the antifreeze starts coming out. otherwise a breeze
reww86
Aug 29, 2015 06:04 PM
MikeWhitener
Aug 2, 2015 06:17 PM
jwade88
Jun 14, 2015 09:38 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
