Waterpump O rings, Opti O rings ?
Old Oct 17, 2004 | 03:17 PM
TobyZ28's Avatar
Well I installed a new opti the other day, the new opti cam with new Orings already on it. The old opti came out without any O rings on it! It is possible that some time in the past my mechanic may not have replaced the O rings when rebuilding the engine. Any idea what kind of effects this could have had on the car? I know it was the source of a small mystery oil leak, but could anything have gotten back into the engine?
Also, people recommended I get new waterpump O rings - I didnt use these at all! I didn't see anythign anywhere which should use them... Anyone able to help me out on where they were supposed to be used?
Old Oct 17, 2004 | 05:23 PM
Re: Waterpump O rings, Opti O rings ?
Likely your old opti o-rings had disintegrated. They seem to be used for stabilizing the shaft and are not used for oil control.
The water pump o-rings fit right where the splines stop on each shaft. They keep dirt out of the coupler.
MikeWhitener
Aug 2, 2015 06:17 PM
88IROC_Z
Jul 22, 2015 11:38 PM
RUNMYTA
Jul 15, 2015 07:50 PM
Catmaigne
Jul 14, 2015 05:17 PM
asilomar244
Jul 12, 2015 05:53 AM
