The waterpump debate, electric or stock.....
I honestly cant decide what i want to do. Building a 383 stroker.
Freeing up the power and getting rid of the bastard water pump drive seal would be awesome, but then comes the reliability problems.
i really do not want to lose a brand new motor b/c a pump dies out, so maybe i should just stay stock?
convince me otherwise!
Electric!!! Summit has the CSI electric for $135. I'm not sure what a stock one goes for, but I don't think an electric is TOO MUCH more than a stock. Either way I'm not putting this 111K mile stocker back on to have it **** out on me in a few months.
There's on dyno graph floating around in another electric WP thread that was ~6 or 7 HP. One can expect ~7-10 rwhp from this. Plus, with this you can use a true double roller timing chain...
The pump installs in the stock housing.
That's gonna be the route I'm going!!!!
I'm sure there's negatives too, but I'm ignoring them
i realize the pros on teh electric pump hehe, but how about the cons, i mean once it goes, it will go and temperature will rise rapidly.
Actually ive got a trick idea for a warning system involved the temperature taht should work as long as the temp sender works the way i think it does.
well you ll obviosly know when the pump goes(electric).but dont they have a warrenty of 3000 hours or so.even if it does die out your motor wont be totalled.just have it towed or get a hose and fill it up and drive back home.im going witht he csi.but cant a stocker give out too?
Not sure where I would vote..
I installed my meziere about three weeks ago.. well now my car is dead waiting for a new one in a parking lot.. I hope I got to it soon enough. I was driving on the Norfolk naval base and smelled coolant.. ugh.. looked at the gauge and it was pegged 250+ parked in a hurry.. but it had left a line of coolant about one hundred feet down the road and was overflowing dexcool everywhere..
Still don't know if there is any damage but man... kindof makes me think whether I would rather of stuck with possible leaks than having the whole thing crap out on me.. This was a pretty expensive swap all together I would hate to tear it apart again...
The car was fine afterwards though, no coolant spilled out so I guess it didn't completely overheat. It's running fine now. That "check gauges" light stands out pretty good when it comes on, if I ever see it again I'm turning the thing off immediately and then try and figure out whats wrong.
Originally posted by SloMofo
I think I will stick with a stock pump on my new motor. I can live without the 7 or so HP
Just to make it easier on you guys, here's the link to Keith's page on the dyno improvements using a Meziere E-WP.
http://www.ws6.com/mod-14.htm
Dan
Dan
I love my Electric water pump, I will NEVER go back. I can swap out my Mezeire in no time if I need to... had it over 2 years now without a hitch, and I drive my car almost every day of the year.
In the Mezeire there's a weep hole in the bottom, but I think it would only leak if the seals go.
