Water Pump Seal
Old Nov 16, 2003 | 02:41 PM
finn's Avatar
Water Pump Seal
GM Part number 12553792.
It's a rubber o-ring about 1/2" outside diameter.
Where does it go?
I'm replacing my Opti and water pump so I ordered one of these seals as well since they're only like 50 cents.
I couldn't locate the original on or near the water pump or Opti drive shafts and I don't see any mention of it in the shop manual.
Car is a 94 T/A.
Thanks in advance for the help!
Finn
Old Nov 16, 2003 | 03:01 PM
kevmor99's Avatar
Haven't seen that...
Old Nov 16, 2003 | 03:56 PM
$hawn's Avatar
Must be the water pump drive shaft o rings, one goes on the water pump drive shaft it's self, and the other on the shaft that goes through the timing cover.
Old Nov 16, 2003 | 08:34 PM
finn's Avatar
Thanks.
Now excuse me if this is a stupid question, but...
Where on the shaft does this O ring go?
In looking at the end that engages with the actual WP drive, there appears to be a small groove behind the splined section. This seems like a logical place for the O ring but can anyone confirm that?
Thanks again.
Old Nov 16, 2003 | 10:00 PM
revtime's Avatar
That is where it goes.
Old Nov 18, 2003 | 07:24 AM
finn's Avatar
Okay.
So what do these O rings do?
The water pump has a pressed in seal to keep the water in and the engine cover has a pressed in seal to keep the oil in. If the O rings go on the pump shafts, it seems like all they're doing is sealing both ends of the shaft coupling. What fer?
Finn
Old Nov 18, 2003 | 07:41 AM
Originally posted by finn
Okay.
Finn
You should dab a little grease on the shafts before installing the coupling. The o-rings seal out dirt and keep the shafts and coupling from grinding themselves into powder.
HectorM52
Jul 30, 2017 11:46 AM
Magenta_Hearts
Mar 29, 2017 08:54 PM
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
